Scheduling Real-time HiL Co-simulation of Cyber-Physical Systems on Multi-core Architectures - Archive ouverte HAL Access content directly
Conference Papers Year :
When designing complex cyber-physical systems, engineers have to integrate numerical models from different modeling environments in order to simulate the whole system and estimate its global performances. Co-simulation refers to such joint simulation of heterogeneous models. If some parts of the system are physically available, it is possible to connect these parts to the co-simulation in a Hardware-in-the-Loop (HiL) approach. In this case, the simulation has to be performed in real-time where models execution consists in periodically reacting to the real (physically available) components and providing periodic output updates. This paper deals with the parallelization and scheduling of real-time Hardware-in-the-Loop co-simulation of numerical models on multi-core architectures. A method for defining real-time constraints that have to be met is proposed. Also, an ILP formulation as well as a heuristic are proposed to solve the problem of scheduling the co-simulation on a multi-core architecture while satisfying the previously defined real-time constraints. The proposed approach is evaluated for different sizes of co-simulations and multi-core processors.
rtcsa2018 (1).pdf (271.28 Ko) Télécharger le fichier
Dates and versions
hal-01887155 , version 1 (04-10-2018)
Identifiers
  • HAL Id : hal-01887155 , version 1
Cite
Salah Eddine Saidi, Nicolas Pernet, Yves Sorel. Scheduling Real-time HiL Co-simulation of Cyber-Physical Systems on Multi-core Architectures. RTCSA2018 - IEEE International Conference on Embedded and Real-Time Computing Systems and Applications, Aug 2018, Hakodate, Japan. ⟨hal-01887155⟩
236 View
145 Download
Share
