Sequential Pattern Mining using FCA and Pattern Structures for Analyzing Visitor Trajectories in a Museum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Nyoman Juniarta
Miguel Couceiro
Amedeo Napoli
Chedy Raïssi
This paper presents our work on mining visitor trajectories in Hecht Museum (Haifa, Israel), within the framework of CrossCult Eu-ropean Project about cultural heritage. We present a theoretical and practical research work about the characterization of visitor trajectories and the mining of these trajectories as sequences. The mining process is based on two approaches in the framework of FCA, namely the mining of subsequences without any constraint and the mining of frequent contiguous subsequences. Both approaches are based on pattern structures. In parallel, a similarity measure allows us to build a hierarchical classification which is used for interpretation and characterization of the trajectories w.r.t. four well-known visiting styles.
Paper 22 - Nyoman.pdf (295.21 Ko) Télécharger le fichier
hal-01887914 , version 1 (04-10-2018)
  • HAL Id : hal-01887914 , version 1
Nyoman Juniarta, Miguel Couceiro, Amedeo Napoli, Chedy Raïssi. Sequential Pattern Mining using FCA and Pattern Structures for Analyzing Visitor Trajectories in a Museum. CLA 2018 - The 14th International Conference on Concept Lattices and Their Applications, Jun 2018, Olomouc, Czech Republic. ⟨hal-01887914⟩
123 Consultations
223 Téléchargements
