Adaptive Estimation for Uncertain Nonlinear Systems: A Sliding-Mode Observer Approach
This paper deals with the problem of adaptive estimation, i.e. the simultaneous estimation of the state and parameters, for a class of uncertain nonlinear systems. A nonlinear adaptive sliding-mode observer is proposed based on a nonlinear parameter estimation algorithm. The nonlinear parameter estimation algorithm provides a rate of convergence faster than exponential while the sliding-mode observer ensures ultimate boundness for the state estimation error attenuating the effects of the external disturbances. Linear matrix inequalities (LMIs) are provided for the synthesis of the adaptive observer and some simulation results show the feasibility of the proposed approach.
Automatique / Robotique
