, Nonlinear and Adaptive Control with Applications, 2008.
Nonlinear Observers and Application, 2007. ,
A class of adaptive extended state observers for nonlinear disturbed systems, IEEE Transactions on Industrial Electronics, vol.62, pp.5858-5869, 2015. ,
Adaptive state observer for Lipschitz nonlinear systems, Systems and control letters, vol.62, pp.319-323, 2013. ,
Adaptive observer for a class of parabolic PDEs, IEEE Transactions on Automatic Control, vol.61, pp.3083-3090, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01260172
Sampled-data adaptive observer for a class of state-affine output-injection nonlinear systems, IEEE Transactions on Automatic Control, vol.61, pp.462-467, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01260152
Adaptive observers for nonlinear parameterized class of nonlinear systems, Automatica, vol.45, pp.2292-2299, 2009. ,
Redesign of adaptive observers for improved parameter identification in nonlinear systems, Automatica, vol.47, pp.403-410, 2010. ,
Adaptive control of nonlinearly parameterized systems with a triangular structure, Automatica, vol.38, pp.115-123, 2002. ,
Adaptive observers and parameter estimation for a class of systems nonlinear in the parameters, Automatica, vol.49, pp.2409-2423, 2013. ,
Adaptive sliding-mode observer design for a selective catalytic reduction system of ground-vehicle diesel engines, IEEE Transactions on Mechatronics, vol.21, pp.2027-2038, 2016. ,
Adaptive sliding-mode observer for sensor fault diagnosis of an industrial gas turbine, Control Engineering Practice, vol.38, pp.57-74, 2015. ,
Adaptive second-order sliding-mode observer-based fault reconstrucion for PEM fuel cell air-feed system, IEEE Transactions on Control Systems Technology, vol.23, pp.1098-1109, 2015. ,
Adaptive sliding-mode-observer-based fault reconstruction for nonlineary systems with parametric unvertainties, IEEE Trans Ind Electron, vol.55, pp.4029-4036, 2008. ,
Design of impulsive adaptive observers for improvement of persistency of excitation, International Journal of Adaptive Control and Signal Processing, vol.29, pp.765-782, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01016332
An adaptive sliding-mode observer for a class of uncertain nonlinear systems, International Journal of Adaptive Control and Signal Processing, vol.32, pp.511-527, 2018. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, System and Control Letters, vol.62, pp.1159-1167, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877148
A Lyapunov formulation of the nonlinear small-gain theorem for interconnected ISS systems, Automatica, vol.32, pp.1211-1215, 1996. ,
The ISS philosophy as a unifying framework for stabilitylike behavior, Lecture Notes in Control and Information Science, vol.2, pp.443-467, 2000. ,
On the input-to-state stability property, European Journal of Control, vol.1, pp.24-36, 1995. ,
