Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
On homogeneity and its application in sliding mode, Int. J. Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.007
URL : https://hal.archives-ouvertes.fr/hal-00942326
Homogeneous state feedback stabilization of homogeneous systems, SIAM J. Control Optimization, vol.38, issue.4, pp.1288-1314, 2000. ,
H? control, stabilization, and input-output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.7, pp.819-829, 2001. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
Finite time stability of differential inclusions, IMA J. Math. Control Inform, vol.22, issue.4, pp.465-475, 2005. ,
Global finite-time stabilization by dynamic output feedback for a class of continuous nonlinear systems, IEEE Transactions on Automatic Control, vol.51, issue.5, pp.879-884, 2006. ,
Semi-global finite-time observers for nonlinear systems, Automatica, vol.44, issue.12, pp.3152-3156, 2008. ,
Finite-time input-to-state stability and applications to finite-time control design, SIAM J. Control Optim, vol.48, issue.7, pp.4395-4418, 2010. ,
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
DOI : 10.1109/cdc.2010.5717345
Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Finite-time and fixedtime stabilization: Implicit lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01098099
, Lyapunov Functions and Stability in Control Theory, 2005.
On the asymptotical stability of solutions of nonstationary differential equation systems with homogeneous right hand sides, Dokl. Akad. Nauk Rossii, vol.349, issue.3, pp.295-296, 1996. ,
Averaging results and the study of uniform asymptotic stability of homogeneous differential equations that are not fast time-varying, SIAM J. Control Optim, vol.37, issue.4, pp.997-1010, 1999. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, pp.1159-1167, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877148
Weighted homogeneity for time-delay systems: Finite-time and independent of delay stability, IEEE Transactions on Automatic Control, vol.61, issue.1, pp.210-215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01145321
A note on delay robustness for homogeneous systems with negative degree, Automatica, vol.79, issue.5, pp.178-184, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01419131
Numerical Analysis for Applied Science, ser. A Wiley-Interscience publication, 1998. ,
, Numerical Methods for Ordinary Differential Equations, 2008.
Realization and discretization of asymptotically stable homogeneous systems, IEEE Transactions on Automatic Control, vol.62, issue.11, pp.5962-5969, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01514350
Stability and robustness of homogeneous differential inclusions, Proc. IEEE CDC, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01371280
On fixed and finite time stability in sliding mode control, IEEE 52nd Annual Conference on Decision and Control (CDC), pp.4260-4265, 2013. ,
Implicit euler numerical simulations of sliding mode systems, System and Control Letters, vol.59, issue.5, pp.284-293, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00374840
Globally stable implicit euler timediscretization of a nonlinear single-input sliding-mode control system, IEEE CDC, pp.5426-5431, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01212601
Lyapunov stability and performance analysis of the implicit discrete sliding mode control, IEEE Transactions on Automatic Control, vol.61, issue.10, pp.3016-3030, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01236159
Multivalued robust tracking control of lagrange systems: Continuous and discretetime algorithms, IEEE Transactions on Automatic Control, vol.62, issue.9, pp.4436-4450, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01254303
A special stability problem for linear multistep methods, BIT Numerical Mathematics, vol.3, issue.1, pp.27-43, 1963. ,
Preservation of stability under discretization of systems of ordinary differential equations, Siberian Math. J, vol.51, issue.3, pp.383-395, 2010. ,
Backward euler discretization of fully nonlinear parabolic problems, Mathematics of Computation, vol.71, issue.237, pp.125-145, 2002. ,
Convergence to equilibrium for the backward euler scheme and applications, Communications on Pure and Applied Analysis, vol.9, issue.3, pp.685-702, 2010. ,
Differential Equations with Discontinuous Righthand Sides, 1988. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.15, pp.273-283, 1966. ,
Nonlinear Systems, ser. NJ 07458, 1996. ,
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.1, pp.80-88, 1958. ,
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, pp.467-473, 1992. ,
On extension of homogeneity notion for differential inclusions, Proceeding of the European Control Conference, pp.2204-2209, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00801818
, Numerical methods in scientific computing. SIAM, 2008.
Proper discretization of homogeneous differentiators, Automatica, vol.50, issue.8, pp.2007-2014, 2014. ,
