Y. Ma, Y. Hou, Y. Liu, and Y. Xue, Research of food safety risk assessment methods based on big data, 2nd IEEE Int. Conf. Big Data Anal, pp.1-5, 2017.
B. Antunovic, A. Mancuso, K. Capak, V. Poljak, and T. Florijan?i?, Background to the preparation of the Croatian food safety strategy, Food Control, vol.19, issue.11, pp.1017-1022, 2008.
L. He and Z. Wang, The method of food safety sampling inspection based on dynamic weight, Math. Modeling Its Appl, vol.2, issue.3-4, pp.4-12, 2013.
F. Li, Y. Lv, Q. Zhu, and X. Lin, Research of food safety event detection based on multiple data sources, Int. Conf. Cloud Comput. Big Data, pp.213-216, 2015.
S. Sonka, Big data and the ag sector: More than lots of numbers, Int. Food Agribusiness Manage. Rev, vol.17, issue.1, pp.1-20, 2014.
I. Khosa and E. Pasero, Defect detection in food ingredients using multilayer perceptron neural network, 2014 World Symp, pp.1-5, 2014.
I. Khosa and E. Pasero, Artificial neural network classifier for quality inspection of nuts, Int. Conf. Robot. Emerg. Allied Technol. Eng, pp.103-108, 2014.
Y. Kung, P. Lin, and C. Kao, An optimal-nearest neighbor for density estimation, Statist. Probability Lett, vol.82, issue.10, pp.1786-1791, 2012.
S. Zhang, Shell-neighbor method and its application in missing data imputation, J. Applied Intelligence, vol.35, pp.123-133, 2011.
J. Wang, Z. Zhang, Z. Chen, and Q. Yuan, Imputation missing values with distance-and density-weighted and quadrant-based nearest neighbors, J. Comput. Inform. Syst, vol.11, issue.1, pp.6605-6613, 2015.
D. Singh and C. K. Reddy, A survey on platforms for big data analytics, J Big Data, vol.2, issue.1, 2015.
G. B. Huang, L. Chen, and C. K. Siew, Universal approximation using incremental constructive feedforward networks with random hidden nodes, IEEE Trans. Neural Netw, vol.17, issue.4, pp.879-892, 2006.
G. Huang, Q. Zhu, and C. Siew, Extreme learning machine: Theory and applications, Neurocomputing, vol.70, issue.1-3, pp.489-501, 2006.
C. Cervellera and D. Maccio, Low-discrepancy points for deterministic assignment of hidden weights in extreme learning machines, IEEE Trans. Neural Netw. Learn. Syst, vol.27, issue.4, pp.891-896, 2016.
S. Li, Z. H. You, H. Guo, X. Luo, and Z. Q. Zhao, Inverse-free extreme learning machine with optimal information updating, IEEE Trans. Cybern, vol.46, issue.5, pp.1229-1241, 2016.
Y. Yang and Q. M. Wu, Extreme learning machine with subnetwork hidden nodes for regression and classification, IEEE Trans. Cybern, vol.46, issue.12, pp.2885-2898, 2016.
Y. Yang and Q. M. Wu, Multilayer extreme learning machine with subnetwork nodes for representation learning, IEEE Trans. Cybern, vol.46, issue.11, pp.2570-2583, 2016.
D. P. Mesquita and J. P. Gomes, Pruning extreme learning machines using the successive projections algorithm, IEEE Latin Amer. Trans, vol.13, issue.12, pp.3974-3979, 2015.
Y. Liu, L. Mei, and S. K. Ooi, Prediction of soil moisture based on extreme learning machine for an apple orchard, IEEE 3rd Int. Conf. Cloud Comput, pp.400-404, 2014.
W. Zheng, X. Fu, and Y. Ying, Spectroscopy-based food classification with extreme learning machine, Chemometrics Intell. Laboratory Syst, vol.139, pp.42-47, 2014.
P. Changpetch and D. K. Lin, Model selection for poisson regression via association rules analysis, Int. J. Statist. Probability, vol.4, issue.2, pp.1-9, 2015.
G. Li and P. Niu, An enhanced extreme learning machine based on ridge regression for regression, Neural Comput. Appl, vol.22, issue.3, pp.803-810, 2013.
