P. A. Ioannou and J. Sun, Robust Adaptive Control, 1996.
URL : https://hal.archives-ouvertes.fr/hal-01394197
A. Astolfi, D. Karagiannis, and R. Ortega, Nonlinear and Adaptive Control with Applications, Communications and Control Engineering, 2008.
G. Besançon, Nonlinear Observers and Application, 2007.
S. Sastry and M. Bodson, Adaptive Control. Stability, Convergence and Robustness, Prentice Hall Advance Reference Series, 1989.
G. Lüders and K. Narendra, An adaptive observer and identifier for linear systems, IEEE Transactions on Automatic Control, vol.18, issue.5, pp.496-499, 1973.
R. Carroll and D. Lindorff, An adaptive observer for single input single output linear systems, IEEE Transactions on Automatic Control, vol.18, issue.5, pp.428-435, 1973.
DOI : 10.1109/tac.1973.1100367
URL : http://hdl.handle.net/2060/19730002848
K. Narendra and A. Annaswamy, Stable Adaptive Systems, 2005.
G. Bastin and M. Gevers, Stable adaptive observers for nonlinear time-varying systems, IEEE Transactions on Automatic Control, vol.33, issue.7, pp.650-658, 1988.
R. Marino and P. Tomei, Global adaptive observers for nonlinear systems via filteres transformations, IEEE Transactions on Automatic Control, vol.37, issue.8, pp.1239-1245, 1992.
DOI : 10.1109/9.151117
R. Marino and P. Tomei, Nonlinear Control Design: Geometric, Adaptive & Robust. London, 1995.
G. Besançon, Remarks on nonlinear adaptive observer design, Systems & Control Letters, vol.41, pp.271-280, 2000.
Q. Zhang, Adaptive observer for multiple-input-multiple-output (MIMO) linear time varying systems, IEEE Transactions on Automatic Control, vol.47, issue.3, pp.525-529, 2002.
DOI : 10.1109/9.989154
A. Xu and Q. Zhang, Nonlinear system fault diagnosis based on adaptive estimation, Automatica, vol.40, issue.7, pp.1181-1193, 2004.
M. Farza, M. Saad, M. Maatoug, T. Kamoun, and M. , Adaptive observers for nonlinearly parameterized class of nonlinear systems, Automatica, vol.45, pp.2292-2299, 2009.
DOI : 10.1016/j.automatica.2009.06.008
Y. Liu, Robust adaptive observer for nonlinear systems with unmodeled dynamic, Automatica, vol.45, pp.1891-1895, 2009.
O. Stamnes, O. Aamo, and G. O. Kaasa, Redesign of adaptive observers for improved parameter identification in nonlinear systems, Automatica, vol.47, pp.403-410, 2011.
I. Y. Tyukin, E. Steur, H. Nijmeijer, and C. Van-leeuwen, Adaptive observers and parameter estimation for a class of systems nonlinear in the parameters, Automatica, vol.49, pp.2409-2423, 2013.
W. H. Chen, W. Yang, and W. X. Zheng, Adaptive impulsive observers for nonlinear systems: Revisited, Automatica, vol.61, pp.232-240, 2015.
DOI : 10.1016/j.automatica.2015.08.018
D. Efimov and A. Fradkov, Design of impulsive adaptive observers for improvement of persistency of excitation, International Journal of Adaptive Control and Signal Processing, vol.29, issue.6, pp.756-782, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01016332
T. Folin, T. Ahmed-ali, F. Giri, L. Burlion, and F. Lamnabhi-lagarrigue, Sampled-data adaptive observer for a class of state-affine output-injection nonlinear systems, IEEE Transactions on Automatic Control, vol.61, issue.2, pp.462-467, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01260152
A. Giri, F. Krstic, M. Burlion, L. Lamnabhi-lagarrigue, and F. , Adaptive observer design with heat pde sensor, Automatica, vol.82, pp.93-100, 2017.
URL : https://hal.archives-ouvertes.fr/hal-02151997
Y. Shtessel, C. Edwards, L. Fridman, and A. Levant, Sliding Mode Control and Observation, 2014.
X. G. Yan and C. Edwards, Adaptive sliding-mode-observer-based fault reconstruction for nonlineary systems with parametric uncertainties, IEEE Transactions on Industrial Electronics November, vol.55, issue.11, pp.4029-4037, 2008.
D. Efimov, C. Edwards, and A. Zolghadri, Enhancement of adaptive observer robustness applying sliding mode techniques, Automatica, vol.72, pp.53-56, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01315009
Z. P. Jiang, I. Mareels, and Y. Wang, A Lyapunov formulation of the nonlinear small-gain theorem for interconnected ISS systems, Automatica, vol.32, issue.8, pp.1211-1215, 1996.
S. Dashkovskiy, D. Efimov, and E. Sontag, Input to state estability and allied system properties, Automation and Remote Control, vol.72, issue.8, pp.1579-1614, 2011.
E. Bernuau, A. Polyakov, D. Efimov, and W. Perruquetti, Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00877148
D. Efimov and A. Fradkov, Adaptive tunning to bifurcation for time-varying nonlinear systems, Automatica, vol.42, issue.3, pp.417-425, 2006.
C. Edwards, X. G. Yan, and S. Spurgeon, On the solvability of the constrained Lyapunov problem, IEEE Transactions on Automatic Control, vol.52, issue.10, 2007.
A. Poznyak, Deterministic Techniques, vol.1, 2008.
H. N. Khalil and . Systems, , 2002.
