Delay dependent stabilization of linear time-varying system with time delay, Asian Journal of Control, vol.11, issue.5, pp.557-563, 2009. ,
Stability properties of Kalman-Bucy filters, Journal of the Franklin Institute, vol.291, issue.2, pp.137-144, 1971. ,
Exponential stability of linear equations arising in adaptive identification, IEEE Transactions on Automatic Control, vol.22, issue.1, pp.83-88, 1977. ,
Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM J. Control Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00362707
State elimination and identifiability of the delay parameter for nonlinear time-delay systems, Automatica, vol.44, issue.5, pp.1373-1378, 2008. ,
High gain observer design for nonlinear systems with time varying delayed measurements, IFAC Proceedings Volumes, vol.44, pp.692-696, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00648634
, Analysis and design of nonlinear control systems, 2008.
, Nonlinear observers and applications, vol.363, 2007.
Asymptotic state prediction for continuous-time systems with delayed input and application to control, European Control Conference (ECC, pp.1786-1791, 2007. ,
The Riccati equation and its bounds, Journal of Computer and System Sciences, vol.6, issue.4, pp.343-353, 1972. ,
Joint state estimation and delay identification for nonlinear systems with delayed measurements, IEEE Transactions on Automatic Control, vol.62, issue.9, pp.4848-4854, 2017. ,
An observer for a class of nonlinear systems with time varying observation delay, Systems & Control Letters, vol.59, issue.5, pp.305-312, 2010. ,
, Chapter, Linear dynamical systems, vol.135, pp.72-87, 1977.
Optimal estimation of dynamic systems, 2012. ,
Lyapunov functions for continuous and discontinuous differentiators, IFAC-PapersOnLine, vol.49, issue.18, pp.660-665, 2016. ,
Asymptotic stabilization in fixed time via sliding mode control. In Decision and control (cdc), pp.6460-6465, 2012. ,
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
Introduction to time-delay systems, 2014. ,
Tutorial on Lyapunov-based methods for time-delay systems, European Journal of Control, vol.20, issue.6, pp.271-283, 2014. ,
Observer design for nonlinear systems under unknown time-varying delays, IEEE Transactions on Automatic Control, vol.58, issue.6, pp.1529-1534, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00749682
Adaptive observers for time-delay nonlinear systems in triangular form, Automatica, vol.45, issue.10, pp.2392-2399, 2009. ,
Contributions to the theory of optimal control, vol.5, pp.102-119, 1960. ,
, Nonlinear systems, 2002.
State estimation for invariant systems on lie groups with delayed output measurements, Automatica, vol.68, pp.254-265, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01326783
A switched system approach to exponential stabilization through communication network, IEEE Transactions on Control Systems Technology, vol.20, issue.4, pp.887-900, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00602327
Fixed-time output stabilization of a chain of integrators, Proc. 55th ieee conference on decision and control (cdc), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01371278
Dynamic observation-prediction for LTI systems with a time-varying delay in the input, 2016 IEEE 55th Conference on Decision and Control (CDC), pp.2302-2307, 2016. ,
Stability analysis for time-varying systems with delay using linear lyapunov functionals and a positive systems approach, IEEE Transactions on Automatic Control, vol.61, issue.3, pp.771-776, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01257336
Control and observer design for nonlinear finite and infinite dimensional systems, vol.322, 2005. ,
Lyapunov approach for analysis and design of second order sliding mode algorithms, Sliding modes after the first decade of the 21st century: State of the art, 2012. ,
Fixed-time stabilization of linear systems via sliding mode control, Variable structure systems (vss), 2012 12th international workshop on, pp.1-6, 2012. ,
A hybrid observer for uniform finite-time state estimation of linear systems, proc. 55th ieee conference on decision and control (cdc), 2016. ,
A gramianbased observer with uniform convergence rate for delayed measurements, European Control Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01895389
A survey on lyapunov-based methods for stability of linear time-delay systems, Frontiers of Computer Science, vol.11, issue.4, pp.555-567, 2017. ,
A chain observer for nonlinear long constant delay systems: A matrix inequality approach, Automatica, vol.65, pp.164-169, 2016. ,
Razumikhin and Krasovskii stability theorems for timevarying time-delay systems, Automatica, vol.71, pp.281-291, 2016. ,
