New interface
Conference papers
Transforming acoustic characteristics to deceive playback spoofing countermeasures of speaker verification systems
Abstract : Automatic speaker verification (ASV) systems use a play-back detector to filter out playback attacks and ensure verification reliability. Since current playback detection models are almost always trained using genuine and played-back speech, it may be possible to degrade their performance by transforming the acoustic characteristics of the played-back speech close to that of the genuine speech. One way to do this is to enhance speech "stolen" from the target speaker before playback. We tested the effectiveness of a playback attack using this method by using the speech enhancement generative adversarial network to transform acoustic characteristics. Experimental results showed that use of this "enhanced stolen speech" method significantly increases the equal error rates for the baseline used in the ASVspoof 2017 challenge and for a light convolutional neu-ral network-based method. The results also showed that its use degrades the performance of a Gaussian mixture model-universal background model-based ASV system. This type of attack is thus an urgent problem needing to be solved.
Complete list of metadata
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/hal-01889910
Contributor : Md Sahidullah Connect in order to contact the contributor
Submitted on : Monday, October 8, 2018 - 10:40:26 AM
Last modification on : Tuesday, July 5, 2022 - 8:38:27 AM
Long-term archiving on: : Wednesday, January 9, 2019 - 1:34:46 PM
File
PID5567621.pdf
Identifiers
  • HAL Id : hal-01889910, version 1
Citation
Fuming Fang, Junichi Yamagishi, Isao Echizen, Md Sahidullah, Tomi Kinnunen. Transforming acoustic characteristics to deceive playback spoofing countermeasures of speaker verification systems. WIFS 2018 - IEEE International Workshop on Information Forensics and Security, Dec 2018, Hong Kong, Hong Kong SAR China. ⟨hal-01889910⟩
Share
Metrics
Record views
128
Files downloads
119
