Prosodic and Pragmatic Values of Discourse Particles in French - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper analyses prosodic properties of three discourse particles (DP) in French: 'alors' ('so'), 'bon' ('well') and 'donc' ('thus'), according to their different pragmatic functions. DP occurrences of these words extracted from a large speech database have been annotated manually with pragmatic labels. For each DP, prosodic characteristics of occurrences of each pragmatic function (conclusive, introductive, etc.) are automatically extracted. Then, for each DP and each pragmatic function, the most frequent F0 forms are retained as the representative forms. Results show that a pragmatic function, common to several discourse particles, gives rise to a uniform prosodic marking, and this lead to suppose that such DPs are most of the time commutable.
ExLing_2018_Discourse-Particles-V1.2.pdf (290.98 Ko) Télécharger le fichier
hal-01889925 , version 1 (08-10-2018)
  • HAL Id : hal-01889925 , version 1
Lou Lee, Katarina Bartkova, Mathilde Dargnat, Denis Jouvet. Prosodic and Pragmatic Values of Discourse Particles in French. ExLing 2018 - 9th Tutorial and Research Workshop on Experimental Linguistics, Aug 2018, Paris, France. ⟨hal-01889925⟩
180 Consultations
152 Téléchargements
