Compositional Verification in Action - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Hubert Garavel
Frédéric Lang
Laurent Mounier
  • Fonction : Auteur
  • PersonId : 858856
Concurrent systems are intrinsically complex and their verification is hampered by the well-known "state-space explosion" issue. Compositional verification is a powerful approach, based on the divide-and-conquer paradigm, to address this issue. Despite impressive results, this approach is not used widely enough in practice, probably because it exists under multiple variants that make knowledge of the field hard to attain. In this article, we highlight the seminal results of Graf & Steffen and propose a survey of compositional verification techniques that exploit (or not) these results.
Garavel-Lang-Mounier-18.pdf (411.8 Ko) Télécharger le fichier
hal-01890246 , version 1 (08-10-2018)
Hubert Garavel, Frédéric Lang, Laurent Mounier. Compositional Verification in Action. FMICS 2018 - 23rd International Conference on Formal Methods for Industrial Critical Systems, Sep 2018, Maynooth, Ireland. pp.189-210, ⟨10.1007/978-3-030-00244-2_13⟩. ⟨hal-01890246⟩
119 Consultations
392 Téléchargements
