Temperature-emissivity separation for LWIR sensing using MCMC, vol.9840, p.98401, 2016. ,
Multi-wavelength pyrometry, Metrologia, vol.17, issue.3, p.103, 1981. ,
A progressive refinement approach to fast radiosity image generation, ACM SIGGRAPH computer graphics, vol.22, issue.4, pp.75-84, 1988. ,
The hemi-cube : A radiosity solution for complex environments, In ACM SIGGRAPH Computer Graphics, vol.19, pp.31-40, 1985. ,
Comparison between multiwavelength infrared and visible pyrometry : Application to metals, Infrared Physics & Technology, vol.51, issue.4, pp.292-299, 2008. ,
Global Illumination Using Progressive Refinement Radiosity. In GPU Gems : Programming Techniques for High-Performance Graphics and GeneralPurpose Computation, vol.2 ,
View-Independent Environment Maps. The Eurographics Association, 1998. ,
Thermal Radiation Heat Transfer, 2010. ,
Radiative Measurements of Temperature, Thermal Measurements and Inverse Techniques, Heat transfer, p.587104377, 2011. ,
