Generating patient specific pseudo-CT of the head from MR using atlas-based regression, Phys Med Biol, vol.60, issue.2, p.825, 2015. ,
Automatic Substitute Computed Tomography Generation and Contouring for Magnetic Resonance Imaging (MRI)-Alone External Beam Radiation Therapy From Standard MRI Sequences, Int J Radiat Oncol Biol Phys, vol.93, issue.5, pp.1144-1153, 2015. ,
Atlas-guided generation of pseudo-CT images for MRI-only and hybrid PET-MRI-guided radiotherapy treatment planning, Phys Med Biol, vol.61, issue.17, pp.6531-6552, 2016. ,
Iterative framework for the joint segmentation and CT synthesis of MR images: application to MRI-only radiotherapy treatment planning, Phys Med Biol, vol.62, issue.11, pp.4237-4253, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01556656
MR-based synthetic CT generation using a deep convolutional neural network method, Med Phys, vol.44, issue.4, pp.1408-1419, 2017. ,
Target definition in prostate, head, and neck, Semin Radiat Oncol, vol.15, issue.3, pp.136-145, 2005. ,
Counterpoint: Opportunities and challenges of a magnetic resonance imaging-only radiotherapy work flow, Semin Radiat Oncol, vol.24, issue.3, pp.175-180, 2014. ,
MRI-only treatment planning: benefits and challenges, Phys Med Biol, vol.63, issue.5, pp.5-6, 2018. ,
Systematic review of synthetic computed tomography generation methodologies for use in magnetic resonance imaging-only radiation therapy, Int J Radiat Oncol Biol Phys, vol.100, issue.1, pp.199-217, 2018. ,
A review of substitute CT generation for MRI-only radiation therapy, Radiat Oncol, vol.12, issue.1, p.28, 2017. ,
Vision 20/20: Magnetic resonance imaging-guided attenuation correction in PET/MRI: Challenges, solutions, and opportunities, Med Phys, vol.43, issue.3, pp.1130-1155, 2016. ,
Feasibility and limitations of bulk density assignment in MRI for head and neck IMRT treatment planning, J Appl Clin Med Phys, vol.15, issue.5, pp.100-111, 2014. ,
MRI-based attenuation correction for PET/MRI using ultrashort echo time sequences, J Nucl Med, vol.51, issue.5, pp.812-818, 2010. ,
A voxel-based investigation for MRI-only radiotherapy of the brain using ultra short echo times, Phys Med Biol, vol.59, issue.23, p.7501, 2014. ,
Zero TE-based pseudo-CT image conversion in the head and its application in PET/MR attenuation correction and MR-guided radiation therapy planning, Magn Reson Med, 2018. ,
MRI-based treatment plan simulation and adaptation for ion radiotherapy using a classification-based approach, Radiat Oncol, vol.8, p.51, 2013. ,
One registration multi-atlas-based pseudo-CT generation for attenuation correction in PET/MRI, Eur J Nucl Med Mol Imaging, vol.43, issue.11, pp.2021-2035, 2016. ,
Attenuation correction synthesis for hybrid PET-MR scanners: Application to brain studies, IEEE Trans Med Imaging, vol.33, issue.12, pp.2332-2341, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01827217
Estimating CT image from MRI data using structured random forest and auto-context model, IEEE Trans Med Imaging, vol.35, issue.1, pp.174-183, 2016. ,
DOI : 10.1109/tmi.2015.2461533
URL : http://europepmc.org/articles/pmc4703527?pdf=render
Zero-Echo-Time and Dixon Deep Pseudo-CT (ZeDD CT): Direct Generation of Pseudo-CT Images for Pelvic PET/MRI Attenuation Correction Using Deep Convolutional Neural Networks with Multiparametric MRI, J Nucl Med, vol.59, issue.5, pp.852-858, 2018. ,
Dosimetric and workflow evaluation of first commercial synthetic CT software for clinical use in pelvis, Phys Med Biol, vol.62, issue.8, pp.2961-2975, 2017. ,
Evaluation of a multi-atlas CT synthesis approach for MRI-only radiotherapy treatment planning, Phys Med, vol.35, pp.7-17, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01827195
An Atlas-Based Electron Density Mapping Method for Magnetic Resonance Imaging (MRI)-Alone Treatment Planning and Adaptive MRI-Based Prostate Radiation Therapy, Int J Radiat Oncol Biol Phys, vol.83, issue.1, pp.5-11, 2012. ,
DOI : 10.1016/j.ijrobp.2011.11.056
MROPERA: A multicenter/multivendor validation of magnetic resonance imaging-only prostate treatment planning using synthetic computed tomography images, Int J Radiat Oncol Biol Phys, vol.99, issue.3, pp.692-700, 2017. ,
Technical Note: MRI only prostate radiotherapy planning using the statistical decomposition algorithm, Med Phys, vol.42, issue.10, pp.6090-6097, 2015. ,
DOI : 10.1118/1.4931417
MR and CT data with multi observer delineations of organs in the pelvic area-part of the Gold Atlas project, Med Phys, 2018. ,
Dosimetric evaluation of synthetic CT relative to bulk density assignment-based magnetic resonance-only approaches for prostate radiotherapy, Radiat Oncol, vol.10, issue.1, p.239, 2015. ,
MRI-based treatment planning with pseudo CT generated through atlas registration, Med Phys, vol.41, issue.5, pp.51711-051718, 2014. ,
DOI : 10.1118/1.4873315
URL : http://europepmc.org/articles/pmc5148041?pdf=render
Deep MR to CT synthesis using unpaired data. International Workshop on Simulation and Synthesis in Medical Imaging, pp.14-23, 2017. ,
DOI : 10.1007/978-3-319-68127-6_2
URL : http://arxiv.org/pdf/1708.01155
A survey on deep learning in medical image analysis, Med Image Anal, vol.42, pp.60-88, 2017. ,
Generating Synthetic CT s from Magnetic Resonance Images using Generative Adversarial Networks, Med Phys, 2018. ,
DOI : 10.1002/mp.13047
Patient specific prostate segmentation in 3-D magnetic resonance images, IEEE Trans Med Imaging, vol.31, issue.10, pp.1955-1964, 2012. ,
DOI : 10.1109/tmi.2012.2211377
Combination strategies in multiatlas image segmentation: application to brain MR data, IEEE Trans Med Imaging, vol.28, issue.8, pp.1266-1277, 2009. ,
DOI : 10.1109/tmi.2009.2014372
Evaluation of whole-body MR to CT deformable image registration, J Appl Clin Med Phys, vol.14, issue.4, pp.238-253, 2013. ,
DOI : 10.1120/jacmp.v14i4.4163
URL : https://aapm.onlinelibrary.wiley.com/doi/pdf/10.1120/jacmp.v14i4.4163
Phase congruency: a low-level image invariant, Psychological research, vol.64, issue.2, pp.136-148, 2000. ,
DOI : 10.1007/s004260000024
, Convolutional networks for biomedical image segmentation. Medical Image Computing and Computer-Assisted Intervention ConferenceMICCAI 2015, pp.234-241, 2015.
DOI : 10.1007/978-3-319-24574-4_28
URL : http://arxiv.org/pdf/1505.04597
, Very deep convolutional networks for large-scale image recognition. ARXIV, 2014.
A nonparametric method for automatic correction of intensity nonuniformity in MRI data, IEEE Trans Med Imaging, vol.17, issue.1, pp.87-97, 1998. ,
Treatment planning of intracranial targets on MRI derived substitute CT data, Radiother Oncol, vol.108, issue.1, pp.118-122, 2013. ,
Magnetic Resonance Imaging-Guided Adaptive Radiation Therapy: A "Game Changer" for Prostate Treatment?, Int J Radiat Oncol Biol Phys, vol.100, issue.2, pp.361-373, 2018. ,
Accuracy of inverse treatment planning on substitute CT images derived from MR data for brain lesions, Radiother Oncol, vol.10, issue.1, p.13, 2015. ,
Accuracy of UTE-MRI-based patient setup for brain cancer radiation therapy, Med Phys, vol.43, issue.1, pp.262-267, 2016. ,
Quantitative characterizations of ultrashort echo (UTE) images for supporting air-bone separation in the head, Phys Med Biol, vol.60, issue.7, p.2869, 2015. ,
