Time-stepping for threedimensional rigid body dynamics, Computer methods in applied mechanics and engineering, vol.177, issue.3, pp.183-197, 1999. ,
Seam carving for content-aware image resizing, ACM Transactions on graphics, vol.26, p.10, 2007. ,
Selectively de-animating video, ACM Trans. Graph, vol.31, issue.4, pp.66-67, 2012. ,
Large steps in cloth simulation, Proceedings of the 25th annual conference on Computer graphics and interactive techniques, pp.43-54, 1998. ,
Patchmatch: a randomized correspondence algorithm for structural image editing, ACM Transactions on Graphics-TOG, vol.28, p.24, 2009. ,
Object-based image editing, ACM Transactions on Graphics, vol.21, pp.777-784, 2002. ,
Physically based video editing, Computer Graphics Forum, vol.35, pp.421-429, 2016. ,
A morphable model for the synthesis of 3d faces, Proceedings of the 26th annual conference on Computer graphics and interactive techniques, pp.187-194, 1999. ,
Principal warps: Thin-plate splines and the decomposition of deformations, IEEE Trans. Pattern Anal. Mach. Intell, vol.11, issue.6, pp.567-585, 1989. ,
Interactive Videos: Plausible Video Editing using Sparse Structure Points, Computer Graphics Forum, 2016. ,
The video mesh: A data structure for image-based three-dimensional video editing, Computational Photography (ICCP), pp.1-8, 2011. ,
Sketch2photo: internet image montage, ACM Transactions on Graphics (TOG), vol.28, issue.5, p.124, 2009. ,
3-sweep: extracting editable objects from a single photo, ACM Transactions on Graphics (TOG), vol.32, issue.6, p.195, 2013. ,
3D-R2N2: A Unified Approach for Single and Multi-view 3D Object Reconstruction, pp.628-644, 2016. ,
Extended free-form deformation: A sculpturing tool for 3d geometric modeling, Proceedings of the 17th Annual Conference on Computer Graphics and Interactive Techniques, SIGGRAPH '90, pp.187-196, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00075308
Real-time simulation of contact and cutting of heterogeneous soft-tissues, Medical Image Analysis, vol.18, issue.2, pp.394-410, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01097108
Visual vibrometry: Estimating material properties from small motions in video, IEEE Trans. Pattern Anal. Mach. Intell. PP, issue.99, pp.1-1, 2016. ,
Image-space modal bases for plausible manipulation of objects in video, ACM Transactions on Graphics (TOG), vol.34, issue.6, p.239, 2015. ,
Rendering synthetic objects into real scenes: Bridging traditional and image-based graphics with global illumination and high dynamic range photography, ACM SIGGRAPH 2008 classes, p.32, 2008. ,
Modeling and rendering architecture from photographs: A hybrid geometry-and image-based approach, Proceedings of the 23rd annual conference on Computer graphics and interactive techniques, pp.11-20, 1996. ,
Textureshop: texture synthesis as a photograph editing tool, ACM Transactions on Graphics (TOG), vol.23, issue.3, pp.354-359, 2004. ,
SOFA: A Multi-Model Framework for Interactive Physical Simulation, In: Soft Tissue Biomechanical Modeling for Computer Assisted Surgery, vol.11, pp.283-321, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00681539
Datadriven object manipulation in images, Computer Graphics Forum, vol.31, pp.265-274, 2012. ,
Light source position and reflectance estimation from a single view without the distant illumination assumption, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.4, pp.493-505, 2005. ,
Moviereshape: Tracking and reshaping of humans in videos, ACM Transactions on Graphics (TOG), vol.29, p.148, 2010. ,
Rendering synthetic objects into legacy photographs, ACM Transactions on Graphics (TOG), vol.30, p.157, 2011. ,
Imagebased material editing, ACM Transactions on Graphics (TOG), vol.25, issue.3, pp.654-663, 2006. ,
3d object manipulation in a single photograph using stock 3d models, ACM Transactions on Graphics (TOG), vol.33, issue.4, p.127, 2014. ,
An edge-based computationally efficient formulation of saint venant-kirchhoff tetrahedral finite elements, ACM Transactions on Graphics (TOG), vol.28, issue.1, 2009. ,
Photo clip art, ACM transactions on graphics (TOG), vol.26, p.3, 2007. ,
Epnp: An accurate o(n) solution to the pnp problem, International Journal of Computer Vision, vol.81, issue.2, p.155, 2008. ,
Mesh-independent surface interpolation, Geometric Modeling for Scientific Visualization, Mathematics and Visualization, pp.37-49, 2004. ,
DOI : 10.1007/978-3-662-07443-5_3
Smash: Physics-guided reconstruction of collisions from videos, ACM Trans. Graph, vol.35, issue.6, p.14, 2016. ,
Physically based deformable models in computer graphics, Computer Graphics Forum, vol.25, issue.4, pp.809-836, 2006. ,
DOI : 10.1111/j.1467-8659.2006.01000.x
Image-based modeling and photo editing, Proceedings of the 28th annual conference on Computer graphics and interactive techniques, pp.433-442, 2001. ,
DOI : 10.1145/383259.383310
Animating pictures of water scenes using video retrieval, Vis. Comput, vol.34, issue.3, pp.347-358, 2018. ,
grabcut": Interactive foreground extraction using iterated graph cuts, ACM Trans. Graph, vol.23, issue.3, pp.309-314, 2004. ,
Labelme: a database and web-based tool for image annotation, International Journal of computer vision, vol.77, issue.1-3, pp.157-173, 2008. ,
Efficient contact modeling using compliance warping, In: computer graphics international, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00844039
Imagining the unseen: Stability-based cuboid arrangements for scene understanding, ACM Trans. Graph, vol.33, issue.6, p.11, 2014. ,
As-rigid-as-possible surface modeling, Symposium on Geometry processing, vol.4, 2007. ,
Separating reflection components of textured surfaces using a single image, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.2, pp.178-193, 2005. ,
Interactive motion photography from a single image, The Visual Computer, vol.26, issue.11, pp.1339-1348, 2010. ,
Real-time expression transfer for facial reenactment, ACM Transactions on Graphics (TOG), vol.34, issue.6, p.183, 2015. ,
DOI : 10.1145/2816795.2818056
Face2face: Real-time face capture and reenactment of rgb videos, Proc. Computer Vision and Pattern Recognition (CVPR), vol.1, 2016. ,
Deep3D: Fully Automatic 2Dto-3D Video Conversion with Deep Convolutional Neural Networks, pp.842-857, 2016. ,
DOI : 10.1007/978-3-319-46493-0_51
URL : http://arxiv.org/pdf/1604.03650
Interactive images: cuboid proxies for smart image manipulation, ACM Trans. Graph, vol.31, issue.4, pp.99-100, 2012. ,
Parametric reshaping of human bodies in images, ACM Trans. Graph, vol.29, issue.4, pp.1-126, 2010. ,
