New interface
Conference papers
Appreciation of the delay in the benefits of the thermal energy released by PCM in civil engineering structures
Résumé : To optimize de-icers use in winter on roads and airports, some sustainable solutions were promoted in a global project entitled "Roads of the Future". PCM into pavements were then considered to rely on the released enthalpy to delay the occurrence of black ice or snow accumulation. Coupling a spectroscopic monitoring of the PCM behavior and thermography on pavement surface indicated a significant delay between the phase change and the thermal manifestation of the released energy. Considering an accurate description of PCM according to cooling weather phenomena, these elements might provide valuable information for numerical models.
Keywords : PCM
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01891265
Contributor : Laurent Mevel Connect in order to contact the contributor
Submitted on : Tuesday, October 9, 2018 - 2:07:58 PM
Last modification on : Friday, June 17, 2022 - 1:27:30 PM
File
QIRT2018_vFinale-preprint.pdf
Identifiers
  • HAL Id : hal-01891265, version 1
Citation
Nicolas Le Touz, Mario Marchetti, Jean Dumoulin, Laurent Peiffer, A. Escal, et al.. Appreciation of the delay in the benefits of the thermal energy released by PCM in civil engineering structures. QIRT 2018, 14th Quantitative InfraRed Thermography Conference, Jun 2018, Berlin, Germany. pp.9 P. ⟨hal-01891265⟩
Share
Metrics
Record views
166
Files downloads
111
