High-performance finite-element simulations of seismic wave propagation in three-dimensional nonlinear inelastic geological media, Parallel Comput, vol.36, issue.5, pp.308-325, 2010. ,
On Scalability Issues of the Elastodynamics Equations on Multicore Platforms, International Conference on Computational Science, vol.18, pp.1226-1234, 2013. ,
Towards Seismic Wave Modeling on Heterogeneous Many-Core Architectures Using Task-Based Runtime System, Proceedings of the 2015 27th International Symposium on Computer Architecture and High Performance Computing, 2015. ,
CHARM++: A Portable Concurrent Object Oriented System Based on, C++. SIGPLAN Not, vol.28, issue.10, pp.91-108, 1993. ,
, Languages and Compilers for Parallel Computing, pp.306-322, 2004.
Performance Evaluation of Adaptive MPI, Proceedings of the Eleventh ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, pp.12-21, 2006. ,
Improving the Performance of Seismic Wave Simulations with Dynamic Load Balancing, Proc. of the 2014 22nd Euromicro Intl. Conf. on Parallel, Distributed, and Network-Based Processing, vol.14, pp.196-203, 2014. ,
Versatile, scalable, and accurate simulation of distributed applications and platforms, J Parallel Distrib Comput, vol.74, issue.10, pp.2899-2917, 2014. ,
Single node on-line simulation of MPI applications with SMPI, Parallel & Distributed Processing Symposium (IPDPS), IEEE Intl, pp.664-675, 2011. ,
Improving the Accuracy and Efficiency of Time-Independent Trace Replay, Proc. of the SC Companion: High Perf. Comp., Networking Storage and Analysis, vol.12, pp.446-455, 2012. ,
On the Validity of Flow-level TCP Network Models for Grid and Cloud Simulations, ACM Trans Model Comput Simul, vol.23, issue.4, p.26, 2013. ,
Méhaut Jean-François. Faithful performance prediction of a dynamic task-based runtime system for heterogeneous multi-core architectures, Concurr Comput, vol.27, issue.16, pp.4075-4090, 2015. ,
Using Simulation to Evaluate and Tune the Performance of Dynamic Load Balancing of an Over-decomposed Geophysics Application, Internatioal European Conference on Parallel and Distributed Computing, pp.192-205, 2017. ,
An Effective Git And Org-Mode Based Workflow For Reproducible Research, SIGOPS Oper Syst Rev, vol.49, issue.1, pp.61-70, 2015. ,
The Finite-Difference Time-Domain Method for Modeling of Seismic Wave Propagation, Advances in Wave Prop. in Heterog. Earth, vol.48, pp.421-516, 2007. ,
Investigation of historical earthquake by seismic wave propagation simulation: Source parameters of the 1887 M6. 3 Ligurian, north-western Italy, earthquake, L'Association Française du Génie Parasismique (AFPS), 2011. ,
PAPI: A Portable Interface to Hardware Performance Counters, Proceedings of the Department of Defense HPCMP Users Group Conference, pp.7-10, 1999. ,
, Model-Based Optimization of EULAG Kernel on Intel Xeon Phi Through Load Imbalancing, IEEE Trans Parallel Distrib Syst, vol.28, issue.3, pp.787-797, 2017.
Finite Difference Simulations of Seismic Wave Propagation for the 2007 Mw 6.6 Niigata-ken Chuetsu-Oki Earthquake: Validity of Models and Reliable Input Ground Motion in the Near-Field, Pure Appl Geophys, vol.170, issue.1-2, pp.43-64, 2013. ,
A topology-aware load balancing algorithm for clustered hierarchical multi-core machines, Future Gener Comput Syst, vol.30, pp.191-201, 2014. ,
Topology-Aware Load Balancing for Performance Portability over Parallel High Performance Systems. PhD thesis UFRGS, 2014. ,
MPC-MPI: An MPI Implementation Reducing the Overall Memory Consumption, Recent Advances in Parallel Virtual Machine and Message Passing Interface, 16th European PVM/MPI Users' Group Meeting Proceedings, pp.94-103, 2009. ,
Toward better simulation of MPI applications on Ethernet/TCP networks, International Workshop on Performance Modeling, pp.158-181, 2013. ,
Simulation of MPI applications with time-independent traces, Concurr Comput, vol.27, issue.5, 2015. ,
ScalaTrace: Scalable compression and replay of communication traces for high-performance computing, J Parallel Distrib Comput, vol.69, issue.8, pp.696-710, 2009. ,
Adding Virtualization Capabilities to the Grid'5000 Testbed, International Conference on Cloud Computing and Services Science (CLOSER), vol.367, pp.3-20, 2013. ,
The Tau Parallel Performance System, Int J High Perform Comput Appl, vol.20, issue.2, pp.287-311, 2006. ,
BigSim: a parallel simulator for performance prediction of extremely large parallel machines, 18th International Parallel and Distributed Processing Symposium, 2004. ,
A Simulator for Large-Scale Parallel Computer Architectures, Int J Distrib Syst Technol, vol.1, issue.2, pp.57-73, 2010. ,
Scaling to a million cores and beyond: Using light-weight simulation to understand the challenges ahead on the road to exascale, Future Gener Comput Syst, vol.30, pp.59-65, 2014. ,
The structural simulation toolkit, SIGMETRICS Perform Eval Rev, vol.38, issue.4, 2011. ,
Adagio: Making DVS Practical for Complex HPC Applications, ICS '09, pp.460-469, 2009. ,
Performance Modeling of a Geophysics Application to Accelerate the Tuning of Over-decomposition Parameters through Simulation, Concurrency and Computation: Practice and Experience, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01891416
