A circuit-based approach to efficient enumeration, 44th International Colloquium on Automata, Languages, and Programming, vol.111, p.15, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01639179
Enumeration of minimal stoichiometric precursor sets in metabolic networks, Algorithms for Molecular Biology, vol.11, issue.1, p.25, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01368653
Reverse search for enumeration, Discrete Applied Mathematics, vol.65, issue.1, pp.21-46, 1996. ,
Mso queries on tree decomposable structures are computable with linear delay, International Workshop on Computer Science Logic, pp.167-181, 2006. ,
Efficient generation of stable planar cages for chemistry, International Symposium on Experimental Algorithms, pp.235-246, 2015. ,
Computing and listing st-paths in public transportation networks, Theory of Computing Systems, vol.62, issue.3, pp.600-621, 2018. ,
Linear delay enumeration and monadic second-order logic, Discrete Applied Mathematics, vol.157, issue.12, pp.2675-2700, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00333846
On generating all solutions of generalized satisfiability problems, vol.31, pp.499-511, 1997. ,
Enumeration complexity of logical query problems with second-order variables, LIPIcs-Leibniz International Proceedings in Informatics, vol.12, 2011. ,
Van den Bussche, and Dries Van Dyck. Naive infinite enumeration of context-free languages in incremental polynomial time, J. UCS, vol.21, issue.7, pp.891-911, 2015. ,
Parameterized complexity theory, 2006. ,
Trie memory, Communications of the ACM, vol.3, issue.9, pp.490-499, 1960. ,
Combinatorial algorithms, part 1, volume 4a of the art of computer programming, 2011. ,
The art of computer programming, vol.3, 1997. ,
On deterministic approximation of dnf, Algorithmica, vol.16, issue.4-5, pp.415-433, 1996. ,
´ Enumération des Dominants Minimaux d'un graphe, 2013. ,
Efficient enumeration of solutions produced by closure operations, 33rd Symposium on Theoretical Aspects of Computer Science, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01388505
Efficient algorithms for dualizing large-scale hypergraphs, Discrete Applied Mathematics, vol.170, pp.83-94, 2014. ,
Generating linear extensions fast, SIAM Journal on Computing, vol.23, issue.2, pp.373-386, 1994. ,
Bounds on backtrack algorithms for listing cycles, paths, and spanning trees, Networks, vol.5, issue.3, pp.237-252, 1975. ,
Enumeration for fo queries over nowhere dense graphs, Proceedings of the 37th ACM SIGMOD-SIGACT-SIGAI Symposium on Principles of Database Systems, SIGMOD/PODS '18, pp.151-163, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01895786
Enumerating with constant delay the answers to a query, Proceedings of the 16th International Conference on Database Theory, pp.10-20, 2013. ,
DOI : 10.1145/2448496.2448498
URL : https://hal.archives-ouvertes.fr/hal-00907085
Enumeration complexity and matroid decomposition, 2010. ,
On enumerating monomials and other combinatorial structures by polynomial interpolation. Theory of Computing Systems, vol.53, pp.532-568, 2013. ,
DOI : 10.1007/s00224-012-9442-z
URL : http://www.prism.uvsq.fr/%7Eystr/poly_longue.pdf
Constant time enumeration by amortization, Workshop on Algorithms and Data Structures, pp.593-605, 2015. ,
DOI : 10.1007/978-3-319-21840-3_49
Constant time generation of free trees, SIAM Journal on Computing, vol.15, issue.2, pp.540-548, 1986. ,
DOI : 10.1137/0215039
URL : http://cs.anu.edu.au/people/bdm/papers/ConstantTimeTrees.pdf
, A Proof of Proposition 1
, We use a Gray code to do this in constant time. More precisely, we represent a model of C in n registers R 1 ,. .. , R n where R i holds the value of x i in this model. We initialize the registers such that R i = 1 if x i ? C and R i = 0 otherwise, The models of C on variables X are exactly the assignments of the form 1 C ? ? for any ? : X \ var(C) ? {0, 1}
We start by storing the values of ? in an array of size k. We then execute Output(1, n) which outputs the first model of C. After that, we run a Gray code enumeration on the subsets of a set of size k. For each new element generated, the Gray code algorithm flips a bit at some position i. We thus switch the bit of R ?(i) and call Output(1, n), n} be such that X \ var(C) = {x ?(1) ,
