Hessian barrier algorithms for linearly constrained optimization problems
Abstract : In this paper, we propose an interior-point method for linearly constrained optimization problems (possibly nonconvex). The method -- which we call the Hessian barrier algorithm (HBA) -- combines a forward Euler discretization of Hessian Riemannian gradient flows with an Armijo backtracking step-size policy. In this way, HBA can be seen as an explicit alternative to mirror descent (MD), and contains as special cases the affine scaling algorithm, regularized Newton processes, and several other iterative solution methods. Our main result is that, modulo a non-degeneracy condition, the algorithm converges to the problem's set of critical points; hence, in the convex case, the algorithm converges globally to the problem's minimum set. In the case of linearly constrained quadratic programs (not necessarily convex), we also show that the method's convergence rate is $\mathcal{O}(1/k^\rho)$ for some $\rho\in(0,1]$ that depends only on the choice of kernel function (i.e., not on the problem's primitives). These theoretical results are validated by numerical experiments in standard non-convex test functions and large-scale traffic assignment problems.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
https://hal.inria.fr/hal-01891539
Contributor : Panayotis Mertikopoulos <>
Submitted on : Tuesday, October 9, 2018 - 4:45:54 PM
Last modification on : Friday, April 19, 2019 - 4:55:28 PM
Links full text
Identifiers
  • HAL Id : hal-01891539, version 1
  • ARXIV : 1809.09449
Citation
Immanuel Bomze, Panayotis Mertikopoulos, Werner Schachinger, Mathias Staudigl. Hessian barrier algorithms for linearly constrained optimization problems. 2018. ⟨hal-01891539⟩
Share
Metrics
Record views
90
