Mitigating Bias in Gender, Age and Ethnicity Classification: a Multi-Task Convolution Neural Network Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This work explores joint classification of gender, age and race. Specifically, we here propose a Multi-Task Convolution Neural Network (MTCNN) employing joint dynamic loss weight adjustment towards classification of named soft biometrics, as well as towards mitigation of soft biometrics related bias. The proposed algorithm achieves promising results on the UTKFace and the Bias Estimation in Face Analytics (BEFA) datasets and was ranked first in the the BEFA Challenge of the European Conference of Computer Vision (ECCV) 2018.
DasDantchevaBremond_ECCVW_18.pdf (305.53 Ko) Télécharger le fichier
hal-01892103 , version 1 (10-10-2018)
  • HAL Id : hal-01892103 , version 1
Abhijit Das, Antitza Dantcheva, Francois Bremond. Mitigating Bias in Gender, Age and Ethnicity Classification: a Multi-Task Convolution Neural Network Approach. ECCVW 2018 - European Conference of Computer Vision Workshops, Sep 2018, Munich, Germany. ⟨hal-01892103⟩
288 Consultations
5696 Téléchargements
