Minimum time control of heterodirectional linear coupled hyperbolic pdes, Automatica, vol.71, pp.300-307, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01477700
Boundary control of coupled reactiondiffusion processes with constant parameters, Automatica, vol.54, pp.80-90, 2015. ,
Finite time stability of continuous autonomous systems, SIAM J. Control Optim, vol.38, issue.3, pp.751-766, 2000. ,
The solution of initial-boundary value problems for parabolic equations by the method of integral operators, Journal of Differential Equations, vol.26, issue.2, pp.181-190, 1977. ,
Finite-time boundary stabilization of general linear hyperbolic balance laws via fredholm backstepping transformation, Automatica, vol.84, pp.95-100, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01437107
Null controllability and finite time stabilization for the heat equations with variable coefficients in space in one dimension via backstepping approach. Archive for Rational Mechanics and Analysis, vol.225, pp.993-1023, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01228895
Adding an integrator for the stabilization problem, Systems & Control Letters, vol.17, issue.2, pp.89-104, 1991. ,
Local exponential H 2 stabilization of a 2 × 2 quasilinear hyperbolic system using backstepping, SIAM Journal on Control and Optimization, vol.51, issue.3, pp.2005-2035, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00726867
Backstepping control of coupled linear parabolic PIDEs with spatially-varying coefficients, IEEE Transactions on Automatic Control, issue.99, pp.1-1, 2018. ,
Necessary and sufficient conditions for complete blow-up and extinction for one-dimensional quasilinear heat equation, Archive for Rational Mechanics and Analysis, vol.129, issue.3, pp.225-244, 1995. ,
Finite time controllers, SIAM Journal of Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
Finite-time and fixed-time observer design: Implicit lyapunov function approach, Automatica, vol.87, pp.52-60, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01622356
Some perspectives in PDE control, Proc. 20th IFAC World Congress, Toulouse (F), 2017. ,
Finite-time multi-agent deployment: A nonlinear PDE motion planning approach, Automatica, vol.47, issue.11, pp.2534-2542, 2011. ,
Tracking control for boundary controlled parabolic PDEs with varying parameters: Combining backstepping and differential flatness, Automatica, vol.45, issue.5, pp.1182-1194, 2009. ,
Output feedback stabilization of coupled reaction-diffusion processes with constant parameters, SIAM Journal on Control and Optimization, vol.55, issue.6, pp.4112-4155, 2017. ,
Finite-time stabilization of 2×2 hyperbolic systems on tree-shaped networks, SIAM Journal on Control and Optimization, vol.52, issue.1, pp.143-163, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00793728
On boundary finite-time feedback control for heat equation, 20th IFAC World Congress, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01505482
On Homogeneous FiniteTime Control For Evaluation Equation in Hilbert Space, IEEE Transactions on Automatic Control, pp.1-1, 2017. ,
, Finite-time and Fixedtime Stabilization: Implicit Lyapunov Function Approach, vol.51, pp.332-340, 2015.
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Closed-form boundary state feedbacks for a class of 1-d partial integro-differential equations, IEEE Transactions on Automatic Control, vol.49, issue.12, pp.2185-2202, 2004. ,
On control design for pdes with space-dependent diffusivity or time-dependent reactivity, Automatica, vol.41, issue.9, pp.1601-1608, 2005. ,
Timevarying feedback for regulation of normal-form nonlinear systems in prescribed finite time, Automatica, vol.83, pp.243-251, 2017. ,
Orthogonal polynomials, American Mathematical Society, vol.23, 1975. ,
Boundary control of coupled reactionadvection-diffusion systems with spatially-varying coefficients, IEEE Transactions on Automatic Control, vol.62, issue.4, pp.2026-2033, 2017. ,
Control for fast and stable laminar-to-high-reynolds-numbers transfer in a 2D Navier-Stokes channel flow, Discrete & Continuous Dynamical Systems-B, vol.10, issue.4, pp.925-956, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00131057
