Even faster accelerated coordinate descent using non-uniform sampling, International Conference on Machine Learning, pp.1110-1119, 2016. ,
Tutorial on large deviations for the binomial distribution, Bulletin of mathematical biology, vol.51, issue.1, pp.125-131, 1989. ,
Synchronization and linearity: an algebra for discrete event systems, 1992. ,
Randomized gossip algorithms, IEEE transactions on information theory, vol.52, pp.2508-2530, 2006. ,
Distributed optimization and statistical learning via the alternating direction method of multipliers, Foundations and Trends R in Machine learning, vol.3, issue.1, pp.1-122, 2011. ,
Accelerated gossip algorithms for distributed computation, Proc. of the 44th Annual Allerton Conference on Communication, Control, and Computation, pp.952-959, 2006. ,
Towards consensus: Some convergence theorems on repeated averaging, Journal of Applied Probability, vol.14, issue.1, pp.89-97, 1977. ,
Reaching a consensus, Journal of the American Statistical Association, vol.69, issue.345, pp.118-121, 1974. ,
Analysis of a nonreversible markov chain sampler, Annals of Applied Probability, pp.726-752, 2000. ,
Efficient schemes for nearest neighbor load balancing, Parallel computing, vol.25, issue.7, pp.789-812, 1999. ,
DOI : 10.1016/s0167-8191(99)00018-6
URL : https://doi.org/10.1016/s0167-8191(99)00018-6
Geographic gossip: efficient aggregation for sensor networks, Proceedings of the 5th international conference on Information processing in sensor networks, pp.69-76, 2006. ,
Gossip algorithms for distributed signal processing, Proceedings of the IEEE, vol.98, issue.11, pp.1847-1864, 2010. ,
Dual averaging for distributed optimization: Convergence analysis and network scaling, IEEE Transactions on Automatic control, vol.57, issue.3, pp.592-606, 2012. ,
Accelerated, parallel, and proximal coordinate descent, SIAM Journal on Optimization, vol.25, issue.4, pp.1997-2023, 2015. ,
DOI : 10.1137/130949993
URL : http://epubs.siam.org/doi/pdf/10.1137/130949993
Multi-step gradient methods for networked optimization, IEEE Trans. Signal Processing, issue.21, pp.5417-5429, 2013. ,
DOI : 10.1109/tsp.2013.2278149
URL : http://arxiv.org/pdf/1211.2132
Accelerated stochastic matrix inversion: general theory and speeding up bfgs rules for faster second-order optimization, 2018. ,
Stochastic dual ascent for solving linear systems, 2015. ,
A2BCD: An asynchronous accelerated block coordinate descent algorithm with optimal complexity, 2018. ,
Location-aided fast distributed consensus, IEEE Transactions on Information Theory, 2007. ,
DOI : 10.1109/tit.2010.2081030
URL : http://arxiv.org/pdf/0707.0500
Asynchronous decentralized parallel stochastic gradient descent, 2017. ,
Asynchronous stochastic coordinate descent: Parallelism and convergence properties, SIAM Journal on Optimization, vol.25, issue.1, pp.351-376, 2015. ,
DOI : 10.1137/140961134
URL : http://arxiv.org/pdf/1403.3862
Analysis of accelerated gossip algorithms, Automatica, vol.49, issue.4, pp.873-883, 2013. ,
DOI : 10.1109/cdc.2009.5399566
URL : https://pure.rug.nl/ws/files/2691129/2009ProcCDCLiu.pdf
An asynchronous parallel stochastic coordinate descent algorithm, The Journal of Machine Learning Research, vol.16, issue.1, pp.285-322, 2015. ,
Accelerated gossip via stochastic heavy ball method, 2018. ,
Some applications of laplace eigenvalues of graphs, Graph symmetry, pp.225-275, 1997. ,
DOI : 10.1007/978-94-015-8937-6_6
URL : http://www.ijp.si/ftp/pub/preprints/ps/97/pp535.ps
Dsa: Decentralized double stochastic averaging gradient algorithm, The Journal of Machine Learning Research, vol.17, issue.1, pp.2165-2199, 2016. ,
DOI : 10.1109/acssc.2015.7421158
Random block coordinate descent methods for linearly constrained optimization over networks, Journal of Optimization Theory and Applications, vol.173, issue.1, pp.227-254, 2017. ,
DOI : 10.1007/s10957-016-1058-z
URL : http://arxiv.org/pdf/1504.06340
Distributed subgradient methods for multi-agent optimization, IEEE Transactions on Automatic Control, vol.54, issue.1, pp.48-61, 2009. ,
DOI : 10.1109/tac.2008.2009515
URL : http://web.mit.edu/asuman/www/documents/distributed-journal-final.pdf
Achieving geometric convergence for distributed optimization over time-varying graphs, SIAM Journal on Optimization, vol.27, issue.4, pp.2597-2633, 2017. ,
Efficiency of coordinate descent methods on huge-scale optimization problems, SIAM Journal on Optimization, vol.22, issue.2, pp.341-362, 2012. ,
DOI : 10.1137/100802001
URL : http://www.uclouvain.be/cps/ucl/doc/core/documents/coredp2010_2web.pdf
Introductory lectures on convex optimization: A basic course, vol.87, 2013. ,
DOI : 10.1007/978-1-4419-8853-9
Efficiency of the accelerated coordinate descent method on structured optimization problems, SIAM Journal on Optimization, vol.27, issue.1, pp.110-123, 2017. ,
Optimization and analysis of distributed averaging with short node memory, IEEE Transactions on Signal Processing, vol.58, issue.5, pp.2850-2865, 2010. ,
Asynchronous gossip algorithms for stochastic optimization, Proceedings of the 48th IEEE Conference on, pp.3581-3586, 2009. ,
Distributed stochastic subgradient projection algorithms for convex optimization, Journal of optimization theory and applications, vol.147, issue.3, pp.516-545, 2010. ,
Hogwild: A lock-free approach to parallelizing stochastic gradient descent, Advances in neural information processing systems, pp.693-701, 2011. ,
Parallel coordinate descent methods for big data optimization, Mathematical Programming, vol.156, issue.1-2, pp.433-484, 2016. ,
Optimal algorithms for smooth and strongly convex distributed optimization in networks, International Conference on Machine Learning, pp.3027-3036, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01478317
Extra: An exact first-order algorithm for decentralized consensus optimization, SIAM Journal on Optimization, vol.25, issue.2, pp.944-966, 2015. ,
DOI : 10.1137/14096668x
URL : http://arxiv.org/pdf/1404.6264
, Decentralized training over decentralized data, vol.2, 2018.
A scheme for robust distributed sensor fusion based on average consensus, Information Processing in Sensor Networks, 2005. IPSN 2005. Fourth International Symposium on, pp.63-70, 2005. ,
Parallelized stochastic gradient descent, Advances in neural information processing systems, pp.2595-2603, 2010. ,
