Nonlinear Acceleration of Momentum and Primal-Dual Algorithms
We describe a convergence acceleration scheme for multistep optimization algorithms. The extrapolated solution is written as a nonlinear average of the iterates produced by the original optimization algorithm. Our scheme does not need the underlying fixed-point operator to be symmetric, hence handles e.g. algorithms with momentum terms such as Nesterov's accelerated method, or primal-dual methods. The weights are computed via a simple linear system and we analyze performance in both online and offline modes. We use Crouzeix's conjecture to show that acceleration performance is controlled by the solution of a Chebyshev problem on the numerical range of a non-symmetric operator modelling the behavior of iterates near the optimum. Numerical experiments are detailed on image processing problems, logistic regression and neural network training for CIFAR10 and ImageNet.
