Restarting Frank-Wolfe
Conditional Gradients (aka Frank-Wolfe algorithms) form a classical set of methods for constrained smooth convex minimization due to their simplicity, the absence of projection step, and competitive numerical performance. While the vanilla Frank-Wolfe algorithm only ensures a worst-case rate of O(1/epsilon), various recent results have shown that for strongly convex functions, the method can be slightly modified to achieve linear convergence. However, this still leaves a huge gap between sublinear O(1/epsilon) convergence and linear O(log(1/epsilon)) convergence to reach an $\epsilon$-approximate solution. Here, we present a new variant of Conditional Gradients, that can dynamically adapt to the function's geometric properties using restarts and thus smoothly interpolates between the sublinear and linear regimes.
