Analyzing Memory Accesses in x86 Executables, Compiler Construction, vol.2985, pp.5-23, 2004. ,
BinCAT: purrfecting binary static analysis, Symp. sur la sécurité des technologies de l'information et des communications, 2017. ,
BAP: A Binary Analysis Platform, Computer Aided Verification, vol.6806, pp.463-469, 2011. ,
Reil: A platform-independent intermediate representation of disassembled code for static code analysis, CanSecWest'09, 2009. ,
Bringing the Web Up to Speed with WebAssembly, Proc. of the 38th Conf. on Programming Language Design and Implementation, pp.185-200, 2017. ,
A FormallyVerified C Static Analyzer, Proc. of the 42Nd Symp. on Principles of Programming Languages, pp.247-259, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078386
Static Analysis of x86 Executables, 2010. ,
Portable software fault isolation, Proc. of the 27th IEEE Computer Security Foundations Symp, pp.18-32, 2014. ,
Formal verification of a realistic compiler, Commun. ACM, vol.52, issue.7, pp.107-115, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00415861
Adaptable Static Analysis of Executables for proving the Absence of Vulnerabilities, 2015. ,
Abstract domains for bit-level machine integer and floating-point operations, Proc. of the Workshops on Automated Theory eXploration and on Invariant Generation, vol.17, pp.55-70, 2012. ,
Rocksalt: Better, Faster, Stronger SFI for the x86, SIGPLAN Not, vol.47, issue.6, pp.395-404, 2012. ,
Adapting software fault isolation to contemporary cpu architectures, Proc. of the 19th USENIX Conf. on Security, pp.1-12, 2010. ,
SoK: (State of) The Art of War: Offensive Techniques in Binary Analysis, IEEE Symp. on Security and Privacy, 2016. ,
Efficient software-based fault isolation, SIGOPS Oper. Syst. Rev, vol.27, issue.5, pp.203-216, 1993. ,
Native client: A sandbox for portable, untrusted x86 native code, Commun. ACM, vol.53, issue.1, pp.91-99, 2010. ,
DOI : 10.1109/sp.2009.25
URL : http://www.muth.org/Robert/Papers/sosp_2009.pdf
? 0 = [s 0 , ? i ], s 0 ? gz , ? 0 , ?, ?, ? (0) , ? 0 with | ? i |= gz. By definition, ? 0 ? F, so we can construct Init ,
, with ? 1 , ? 1 ? Acc and ? 1 , ? 1 ? ? 2 , ? 2. By induction hypothesis, we also have S
By case analysis on the rule that allows ? , we have: ? (FunAssign) The preconditions are the same as for (Assign) ,
, FunCrash) Similar reasoning
, ? (FunStF) Here, the preconditions are either true for (StoreFrame) or (StoreCrash) because of Lemma 3
, ? (FunLdS) Here, the preconditions are either true for (LoadStack) or (LoadCrash) because of Lemma 3
