From attribute-labels to faces: face generation using a conditional generative adversarial network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Facial attributes are instrumental in semantically characterizing faces. Automated classification of such attributes (i.e., age, gender, ethnicity) has been a well studied topic. We here seek to explore the inverse problem, namely given attribute-labels the generation of attribute-associated faces. The interest in this topic is fueled by related applications in law enforcement and entertainment. In this work, we propose two models for attribute-label based facial image and video generation incorporating 2D and 3D deep conditional generative adversarial networks (DCGAN). The attribute-labels serve as a tool to determine the specific representations of generated images and videos. While these are early results, our findings indicate the methods' ability to generate realistic faces from attribute labels.
Wang_Dantcheva_Bremond_ECCVW_18.pdf (7.22 Mo) Télécharger le fichier
hal-01894150 , version 1 (12-10-2018)
  • HAL Id : hal-01894150 , version 1
Yaohui Wang, Antitza Dantcheva, Francois Bremond. From attribute-labels to faces: face generation using a conditional generative adversarial network. ECCVW'18, 5th Women in Computer Vision (WiCV) Workshop in conjunction with the European Conference on Computer Vision, Sep 2018, Munich, Germany. ⟨hal-01894150⟩
109 Consultations
316 Téléchargements
