From touch to vibrations. I: Timing in the grand piano action, J. Acoust. Soc. Am, vol.88, issue.1, pp.52-63, 1990. ,
, From touch to vibrations. III: String motion and spectra, J. Acoust. Soc. Am, vol.93, issue.4, pp.2181-2196, 1993.
Coupled piano strings, J. Acoust. Soc. Am, vol.62, issue.6, pp.1474-1484, 1977. ,
Generation of partials due to nonlinear mixing in a stringed instrument, J. Acoust. Soc. Am, vol.105, issue.1, pp.536-545, 1999. ,
Dispersion of waves in piano strings, J. Acoust. Soc. Am, vol.83, issue.1, pp.305-317, 1988. ,
Design and tone in the mechanoacoustic piano. Part I. Piano hammers and tonal effects, J. Acoust. Soc. Am, vol.99, issue.6, pp.3286-3296, 1996. ,
Contribution of the vibration of various piano components in the resulting piano sound, 22nd International Congress on Acoustics ICA 2016, pp.1-10, 2016. ,
Synthesizing musical sounds by solving the wave equation for vibrating objects, Audio Eng. Soc, vol.19, pp.542-51, 1971. ,
Numerical simulations of piano strings. I. A physical model for a struck string using finite difference methods, J. Acoust. Soc. Am, vol.95, issue.2, pp.1112-1118, 1994. ,
The simulation of piano string vibration: From physical models to finite difference schemes and digital waveguides, J. Acoust. Soc. Am, vol.114, issue.2, pp.1095-1107, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00088329
Physical modeling of the piano, EURASIP J. on Applied Signal Process, vol.2004, issue.7, pp.926-933, 2004. ,
Modeling and simulation of a grand piano, The Journal of the Acoustical Society of America, vol.134, issue.1, pp.648-665, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00768234
, Theoretical acoustics, 1968.
Bandwidth of perceived inharmonicity for physical modeling of dispersive strings, IEEE Trans. Speech Audio Process, vol.7, issue.5, pp.597-601, 1999. ,
, Méthodes Numériques, 2007.
Conservative numerical methods for nonlinear strings, J. Acoust. Soc. Am, vol.118, issue.5, pp.3316-3327, 2005. ,
Generation of longitudinal vibrations in piano strings: From physics to sound synthesis, J. Acoust. Soc. Am, vol.117, issue.4, pp.2268-2278, 2005. ,
Energy-conserving finite difference schemes for tension-modulated strings, Proc. IEEE Int. Conf. Acoust. Speech and Signal Process, pp.285-288, 2004. ,
Double polarisation in nonlinear vibrating piano strings, Vienna talk 2015 on music Acoustics, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01194580
Dynamic modeling and experimental testing of a piano action mechanism with a flexible hammer shank, Journal of computational and nonlinear dynamics, vol.3, issue.3, p.31004, 2008. ,
Non-smooth dynamics for an efficient simulation of the grand piano action, Meccanica, vol.52, issue.11-12, pp.2837-2854, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01331941
Model for piano hammers: Experimental determination and digital simulation, J. Acoust. Soc. Am, vol.83, issue.2, pp.746-754, 1988. ,
Experimental and theoretical studies of piano hammer, Proceedings of the Stockholm Music Acoustics Conference, vol.485, 2003. ,
Energy based simulation of a Timoshenko beam in non-forced rotation. Application to the flexible piano hammer shank, Journal of Sound and Vibration, vol.333, issue.26, pp.7198-7215, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00929938
Numerical simulation of a piano soundboard under downbearing, J Acoust Soc Am, vol.123, p.2401, 2008. ,
The effect of transverse shear deformation on the bending of elastic plates, J. Appl. Mech, vol.12, pp.69-77, 1945. ,
Vibroacoustics of the piano soundboard:(non) linearity and modal properties in the low-and mid-frequency ranges, Journal of Sound and Vibration, vol.332, issue.5, pp.1288-1305, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00743291
Piano acoustics : string's double polarisation and piano source identification, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01755039
Sound synthesis for nonlinear plates, Proc. Conf. on Digital Audio Effects, pp.243-248, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01354772
Time Domain Simulation of a Piano, ESAIM: Mathematical Modelling and Numerical Analysis, vol.2, issue.1, pp.93-133, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00739380
Energy analysis of structural changes in pianos, Vienna Talk on Music Acoustics, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01296947
Perceptual tolerances for decay parameters in plucked string synthesis, J. Audio Eng. Soc, vol.49, issue.11, pp.1049-1059, 2001. ,
Techniques for digital filter design and system identification with application to the violin, 1983. ,
Splitting the unit delay-tools for fractional delay filter design, IEEE Sign. Proc. Mag, vol.13, issue.1, pp.30-60, 1996. ,
Physics-based sound synthesis of string instruments including geometric nonlinearities, 2006. ,
, Physics-based sound synthesis of the piano, vol.54, 2000.
Developments for the commuted piano, Proc. Int. Computer Music Conf, pp.319-326, 1995. ,
Toward next-generation digital keyboard instruments, IEEE Signal Process. Mag, vol.24, issue.2, pp.12-20, 2007. ,
Modeling piano sound using digital waveguide filtering techniques, Proc. Int. Computer Music Conf, pp.89-95, 1987. ,
A physical piano model for music performance, Proc. Int. Computer Music Conf, pp.350-353, 1997. ,
Perception of longitudinal components in piano string vibrations, J. Acoust. Soc. Am. Exp. Lett, vol.128, issue.3, pp.117-128, 2010. ,
A modal-based real-time piano synthesizer, IEEE Trans. Audio, Speech, and Lang. Process, vol.18, issue.4, pp.809-821, 2010. ,
Distributed piano soundboard modeling with common-pole parallel filters, Proc. Stockholm Music Acoust. Conf, pp.641-647, 2013. ,
