Developmental mechanisms underlying variable, invariant and plastic phenotypes, Annals of Botany, vol.117, pp.733-748, 2016. ,
DOI : 10.1093/aob/mcw016
URL : https://academic.oup.com/aob/article-pdf/117/5/733/17850377/mcw016.pdf
Phenomics allows identification of genomic regions affecting maize stomatal conductance with conditional effects of water deficit and evaporative demand, Plant, Cell & Environment, vol.41, pp.314-326, 2018. ,
Uncertainty in simulating wheat yields under climate change, Nature Climate Change, vol.3, pp.827-832, 2013. ,
DOI : 10.1038/nclimate1916
URL : https://hal.archives-ouvertes.fr/hal-01186886
Interspecific competition in Arabidopsis thaliana: a knowledge gap is starting to close, Progress in Botany, vol.76, pp.303-319, 2015. ,
DOI : 10.1007/978-3-319-08807-5_12
A robot-assisted imaging pipeline for tracking the growths of maize ear and silks in a high-throughput phenotyping platform, Plant Methods, vol.13, pp.714-718, 2008. ,
High-throughput estimation of incident light, light interception and radiation-use efficiency of thousands of plants in a phenotyping platform, New Phytologist, vol.212, pp.269-281, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01229560
What is the most prominent factor limiting photosynthesis in different layers of a greenhouse cucumber canopy?, Annals of Botany, vol.114, pp.677-688, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01132281
Quantification of the effects of architectural traits on dry mass production and light interception of tomato canopy under different temperature regimes using a dynamic functionalstructural plant model, Journal of Experimental Botany, vol.65, pp.6399-6410, 2014. ,
High temperature and vapor pressure deficit aggravate architectural effects but ameliorate nonarchitectural effects of salinity on dry mass production of tomato, Frontiers in Plant Science, vol.6, pp.1086-1095, 1438. ,
A large maize (Zea mays L.) SNP genotyping array: development and germplasm genotyping, and genetic mapping to compare with the B73 reference genome, Plant, Cell & Environment, vol.6, pp.1058-1067, 2011. ,
Image Harvest: an open-source platform for high-throughput plant image processing and analysis, Journal of Experimental Botany, vol.67, pp.3587-3599, 2016. ,
DOI : 10.1093/jxb/erw176
URL : https://academic.oup.com/jxb/article-pdf/67/11/3587/18073688/erw176.pdf
A theory of shape by space carving, International Journal of Computer Vision, vol.38, pp.199-218, 2000. ,
Estimating wheat green area index from ground-based LiDAR measurement using a 3D canopy structure model, Agricultural and Forest Meteorology, vol.247, pp.12-20, 2017. ,
DOI : 10.1016/j.agrformet.2017.07.007
URL : https://hal.archives-ouvertes.fr/hal-01573077
Climate trends and global crop production since 1980, Science, vol.333, pp.616-620, 2011. ,
DOI : 10.1126/science.1204531
Marching cubes: a high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, pp.163-169, 1987. ,
DOI : 10.1145/37402.37422
URL : http://www-ee.uta.edu/Online/Devarajan/ee6358/marching cubes algorithm.pdf
Relative contributions of light interception and radiation use efficiency to the reduction of maize productivity under cold temperatures, Functional Plant Biology, vol.35, pp.51-69, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01192233
Light interception of contrasting azimuth canopies under square and rectangular plant spatial distributions: simulations and crop measurements, Field Crops Research, vol.70, pp.1-13, 2001. ,
DOI : 10.1016/s0378-4290(00)00144-1
Differential manipulation of leaf angle throughout the canopy: current status and prospects, Journal of Experimental Botany, vol.68, pp.5699-5717, 2017. ,
Multimodel ensembles of wheat growth: many models are better than one, Global Change Biology, vol.21, pp.911-925, 2015. ,
DOI : 10.1111/gcb.12768
URL : http://eprints.whiterose.ac.uk/81482/1/gcb12768.pdf
3D sorghum reconstructions from depth images identify QTL regulating shoot architecture, Plant Physiology, vol.172, pp.823-834, 2016. ,
DOI : 10.1104/pp.16.00948
URL : http://www.plantphysiol.org/content/172/2/823.full.pdf
Genome-wide analysis of yield in Europe: allelic effects vary with drought and heat scenarios, Plant Physiology, vol.172, pp.749-764, 2016. ,
Climate and efficiency ofcrop production in Britain, Philosophical Transactions of the Royal Society of London Series B: Biological, vol.281, pp.277-294, 1977. ,
Acclimation of leaf nitrogen to vertical light gradient at anthesis in wheat is a whole-plant process that scales with the size of the canopy, Plant Physiology, vol.160, pp.1479-1490, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01001606
A new method to estimate photosynthetic parameters through net assimilation rateintercellular space CO 2 concentration (A-C i ) curve and chlorophyll fluorescence measurements, New Phytologist, vol.213, pp.1543-1554, 2017. ,
DOI : 10.1111/nph.14260
URL : https://hal.archives-ouvertes.fr/hal-01604224
Trade-off between light interception efficiency and light use efficiency: implications for species coexistence in one-sided light competition, Journal of Ecology, vol.102, pp.167-175, 2014. ,
DOI : 10.1111/1365-2745.12184
URL : http://onlinelibrary.wiley.com/doi/10.1111/1365-2745.12184/pdf
Redesigning photosynthesis to sustainably meet global food and bioenergy demand, Proceedings of the National Academy of Sciences, vol.112, pp.8529-8536, 2015. ,
DOI : 10.1073/pnas.1424031112
URL : http://europepmc.org/articles/pmc4507207?pdf=render
, New Phytologist, vol.194, pp.760-774, 2016.
Automated recovery of three-dimensional models of plant shoots from multiple color images, Plant Physiology, vol.166, pp.1688-1698, 2014. ,
InfraPhenoGrid: a scientific workflow infrastructure for plant phenomics on the grid, Future Generation Computer Systems, vol.67, pp.341-353, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01336655
OpenAlea: a visual programming and component-based software platform for plant modelling, ACM SSDBM'15: Proceedings of the 27th International Conference on Scientific and Statistical Database Management, vol.35, 2008. ,
Quantifying the three main components of salinity tolerance in cereals, Plant, Cell & Environment, vol.32, pp.237-249, 2009. ,
Achieving yield gains in wheat, Plant, Cell & Environment, vol.35, pp.1799-1823, 2012. ,
Quantitative plant resistance in cultivar mixtures: wheat yellow rust as a modeling case study, New Phytologist, vol.200, pp.888-897, 2013. ,
A test of the adaptive plasticity hypothesis using transgenic and mutant plants diabled in phytochromemediated elongation responses to neighbors, American Naturalist, vol.146, pp.937-953, 1995. ,
RATP: a model for simulating the spatial distribution of radiation absorption, transpiration and photosynthesis within canopies: application to an isolated tree crown, Plant, Cell & Environment, vol.24, pp.395-406, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-01189639
A meta-analysis of responses of canopy photosynthetic conversion efficiency to environmental factors reveals major causes of yield gap, Journal of Experimental Botany, vol.64, pp.3723-3733, 2013. ,
Varietal mixtures: a viable strategy for sustainable productivity in subsistence agriculture, Annals of Applied Biology, vol.128, pp.1256-1262, 1996. ,
The genetics underlying natural variation of plant-plant interactions, a beloved but forgotten member of the family of biotic interactions, The Plant Journal, vol.93, pp.747-770, 2018. ,
Plant phenomics, from sensors to knowledge, Current Biology, vol.27, pp.770-783, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01608414
Genetic and physiological controls of growth under water deficit, Plant Physiology, vol.164, pp.1628-1635, 2014. ,
The physiological basis of drought tolerance in crop plants: a scenario-dependent probabilistic approach, Annual Review of Plant Biology, vol.69, pp.733-759, 2018. ,
Dissection and modelling of abiotic stress tolerance in plants, Current Opinion in Plant Biology, vol.13, pp.206-212, 2010. ,
Yield gain and risk minimization in maize (Zea mays) through cultivar mixtures in semi-arid zones of the rift valley in Ethiopia, Experimental Agriculture, vol.31, pp.161-168, 1995. ,
The growth of vegetative and reproductive structures (leaves and silks) respond similarly to hydraulic cues in maize, New Phytologist, vol.212, pp.377-388, 2016. ,
A powerful tool for genome analysis in maize: development and evaluation of the high density 600 k SNP genotyping array, Journal of Experimental Botany, vol.15, pp.363-378, 1992. ,
Evolutionary agroecology: individual fitness and population yield in wheat (Triticum aestivum), Ecology, vol.98, pp.2261-2266, 2017. ,
Connecting biochemical photosynthesis models with crop models to support crop improvement. Frontiers in Plant Science 7, 1518. Zhu XG, Long SP, Ort DR, Annual Review of Plant Biology, vol.61, pp.235-261, 2010. ,
