FEDERATED LEARNING IN DISTRIBUTED MEDICAL DATABASES: META-ANALYSIS OF LARGE-SCALE SUBCORTICAL BRAIN DATA (SUPPLEMENTARY MATERIAL)
This document contains the acknowledgements for the work: Federated Learning in Distributed Medical Databases: Meta-Analysis of Large-Scale Subcortical Brain Data. We extend our thanks to all the collaborators and founders that make this work possible.
Paper_ISBI_2019___Santiago__Acknowledgements_.pdf (64.82 Ko)
Télécharger le fichier
