Fractional-Order-Based ACC/CACC Algorithm for Improving String Stability
Traffic flow optimization and driver comfort enhancement are the main contributions of an Adaptive Cruise Control (ACC) system. If communication links are added, more safety and shorter gaps can be reached performing a Cooperative-ACC (CACC). Although shortening the inter-vehicular distances directly improves traffic flow, it can cause string unstable behavior. This paper presents fractional-order-based control algorithms to enhance the car-following and string stability performance for both ACC and CACC vehicle strings, including communication temporal delay effects. The proposed controller is compared with state-of-the-art implementations, exhibiting better performance. Simulation and real experiments have been conducted for validating the approach.
