A high-order discontinuous Galerkin method for 1D wave propagation in a nonlinear heterogeneous medium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2018
We propose a nodal high-order discontinuous Galerkin method for 1D wave propagation in nonlinear media. We solve the elastodynamic equations written in the velocity-strain formulation and apply an upwind flux adapted to heterogeneous media with nonlinear constitutive behavior coupling stress and strain. Accuracy, convergence and stability of the method are studied through several numerical applications. Hysteresis loops distinguishing loading and unloading-reloading paths are also taken into account. We investigate several effects of nonlinearity in wave propagation, such as the generation of high frequencies and the frequency shift of resonant peaks to lower frequencies. Finally, we compare the results for both nonlinear models, with and without hysteresis, and highlight the effects of the former on the stabilization of the numerical scheme.
Fichier non déposé
hal-01896783 , version 1 (16-10-2018)
Simon Chabot, Nathalie Glinsky, Enrique Diego Mercerat, Luis Fabian Bonilla. A high-order discontinuous Galerkin method for 1D wave propagation in a nonlinear heterogeneous medium. Journal of Computational Physics, 2018, 355, pp.191 - 213. ⟨10.1016/j.jcp.2017.11.013⟩. ⟨hal-01896783⟩
158 Consultations
0 Téléchargements
