Large-scale simulation of elastic wave propagation in heterogeneous media on parallel computers, Comput. Methods Appl. Mech. Eng, vol.152, pp.85-102, 1998. ,
The seismic response of sediment-filled valleys. Part 1: the case of incident SH waves, Bull. seism. Soc. Am, vol.70, pp.1263-1286, 1980. ,
The seismic response of sediment-filled valleys. Part 2: the case of incident P and SV waves, Bull. seism. Soc. Am, vol.70, pp.1921-1941, 1980. ,
The two-dimensional resonance of sediment-filled valleys, Bull. seism. Soc. Am, vol.75, pp.519-541, 1985. ,
Dynamic non-planar crack rupture by a finite volume method, Geophys. J. Int, vol.171, issue.1, pp.271-285, 2007. ,
3D dynamic rupture simulation by a finite volume method, Geophys. J. Int, vol.178, issue.1, pp.541-560, 2009. ,
Domain reduction method for three-dimensional earthquake modeling in localized regions. Part I: theory, Bull. seism. Soc. Am, vol.93, pp.817-824, 2003. ,
, Spectral Methods in Fluid Dynamics, 1988.
Seismic waves in heterogeneous material: subcell resolution of the discontinuous Galerkin method, Geophys. J. Int, vol.182, issue.1, pp.250-264, 2010. ,
, Discontinuous Galerkin Methods: Theory, Compuration and Applications, 2000.
Higher order triangular finite elements with mass lumping for the wave equation, SIAM J. Numer. Anal, vol.38, issue.6, pp.2047-2078, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-01010373
RegSEM: a versatile code based on the spectral element method to compute seismic wave propagation at the regional scale, Geophys. J. Int, vol.188, issue.3, pp.1203-1220, 2012. ,
URL : https://hal.archives-ouvertes.fr/insu-01399964
Grid dispersion and stability criteria of some common finite-element methods for acoustic and elastic wave equations, Geophysics, vol.72, issue.6, pp.81-95, 2007. ,
The interior penalty discontinuous Galerkin method for elastic wave propagation: grid dispersion, Geophys. J. Int, vol.175, issue.1, pp.83-93, 2008. ,
An arbitrary highorder discontinuous Galerkin method for elastic waves on unstructured meshes-IV. Anisotropy, Geophys. J. Int, vol.169, issue.3, pp.1210-1228, 2007. ,
Verification of a spectral-element method code for the Southern California Earthquake Center LOH.3 viscoelastic case, Bull. seism. Soc. Am, vol.101, issue.6, pp.2855-2865, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00660332
Analysis of a high-order space and time discontinuous Galerkin method for elastodynamic equations. application to 3D wave propagation, ESAIM Math. Mod. Numer. Anal, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01109424
A high-order discontinuous Galerkin method for the seismic wave propagation, ESAIM Proceedings, vol.27, pp.70-89, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00868418
Spectral methods on triangles and other domains, J. Sci. Comput, vol.6, pp.345-390, 1991. ,
An arbitrary high-order discontinuous Galerkin method for elastic waves on unstructured meshes-II: the threedimensional isotropic case, Geophys. J. Int, vol.167, issue.1, pp.319-336, 2006. ,
An arbitrary high order Discontinuous Galerkin method for elastic waves on unstructured meshes-V. Local time stepping and p-adaptivity, Geophys. J. Int, vol.171, issue.2, pp.695-717, 2007. ,
High degree efficient symmetrical Gaussian quadrature rules for the triangle, Int. J. Numer. Methods Eng, vol.21, pp.1129-1148, 1985. ,
DOI : 10.1002/nme.1620210612
An hp-adaptive discontinuous Galerkin finite-element method for 3D elastic wave modelling, Geophys. J. Int, vol.183, issue.2, pp.941-962, 2010. ,
DOI : 10.1111/j.1365-246x.2010.04764.x
URL : https://hal.archives-ouvertes.fr/insu-00565022
2D and 3D elastic wave propagation by a pseudo-spectral domain decomposition method, J. Seismol, vol.1, pp.237-251, 1997. ,
Non-conforming hybrid meshes for efficient 2-D wave propagation using the discontinuous Galerkin method, Geophys. J. Int, vol.184, issue.2, pp.746-758, 2011. ,
DOI : 10.1111/j.1365-246x.2010.04858.x
Stable spectral methods on tetrahedral elements, SIAM J. Sci. Comput, vol.21, issue.6, pp.2352-2380, 2000. ,
DOI : 10.1137/s1064827598343723
URL : https://infoscience.epfl.ch/record/190447/files/SIAM J Sci Comput 2000 Hesthaven.pdf
, Nodal Discontinuous Galerkin Methods: Algorithms, Analysis, and Applications, vol.54, 2008.
DOI : 10.1007/978-0-387-72067-8
URL : http://cds.cern.ch/record/1639216/files/9780387720678_TOC.pdf
, Spectral/hp Element Methods for Continuum Fluid Dynamics, 1999.
DOI : 10.1093/acprof:oso/9780198528692.001.0001
An arbitrary high order discontinuous Galerkin method for elastic waves on unstructured meshes-I: the twodimensional isotropic case with external source terms, Geophys. J. Int, vol.166, issue.2, pp.855-877, 2006. ,
An arbitrary high-order discontinuous Galerkin method for elastic waves on unstructured meshes-III. Viscoelastic attenuation, Geophys. J. Int, vol.168, issue.1, pp.224-242, 2007. ,
Accurate calculation of faultrupture models using the high-order discontinuous galerkin method on tetrahedral meshes, Bull. seism. Soc. Am, vol.97, issue.5, pp.1570-1586, 2007. ,
The spectral-element method: an efficient tool to simulate the seismic response of 2D and 3D geological structures, Bull. seism. Soc. Am, vol.88, issue.2, pp.368-392, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00669068
Wave propagation in 2-D elastic media using a spectral element method with triangles and quadrangles, J. Comput. Acoust, vol.9, issue.2, pp.703-718, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00528424
Two-variable analogues of the classical orthogonal polynomials, Theory and Applications of Special Functions, pp.435-495, 1975. ,
Geothecnical Earthquake Engineering, 1996. ,
Time-frequency misfit and goodness-of-fit criteria for quantitative comparison of time signals, Geophys, J. Int, vol.178, pp.813-825, 2009. ,
Fekete-Gauss finite elements for incompressible Navier-Stokes flows, Commun. Comput. Phys, vol.13, issue.5, pp.1309-1329, 2013. ,
Dispersion analysis of the spectral element method using a triangular mesh, Wave Motion, vol.49, issue.4, pp.474-483, 2012. ,
Dispersion analysis of triangle-based spectral element methods for elastic wave propagation, Numer. Algorith, vol.60, pp.631-650, 2012. ,
DOI : 10.1007/s11075-012-9592-8
URL : https://hal.archives-ouvertes.fr/hal-00946519
SPEED: SPectral Elements in Elastodynamics with Discontinuous Galerkin: a non-conforming approach for 3D multi-scale problems, Int. J. Numer. Methods Eng, vol.95, issue.12, pp.991-1010, 2013. ,
DOI : 10.1002/nme.4532
Triangular spectral element simulation of 2D elastic wave propagation using unstructured triangular grids, Geophys. J. Int, vol.166, pp.679-698, 2006. ,
, The Finite-Difference Modelling of Earthquake Motions: Waves and Ruptures, 2014.
Terashake2: spontaneous rupture simulations of Mw, Bull. seism. Soc. Am, vol.98, issue.3, pp.1162-1185, 2008. ,
Spectral approximation on the triangle, Proc. R. Soc. Lond., A, vol.454, pp.857-872, 1998. ,
Spectral element methods on unstructured meshes: comparisons and recent advances, J. Sci. Comput, vol.27, issue.1-3, pp.377-387, 2006. ,
Spectral element methods on unstructured meshes: which interpolation points?, Numer. Algorith, vol.55, issue.2, pp.349-366, 2010. ,
Forward and adjoint simulations of seismic wave propagation on fully unstructured hexahedral meshes, Geophys. J. Int, vol.186, issue.2, pp.721-739, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00617249
A nodal discontinuous Galerkin method for site effects assessment in viscoelastic mediaverification and validation in the Nice basin, Geophys. J. Int, vol.199, issue.1, pp.315-334, 2014. ,
Sur une famille de polynomesàpolynomes`polynomesà deux variables orthogonaux dans un triangle, C. R. Acad. Sci, vol.245, pp.2459-2461, 1957. ,
Introduction to the supplement on seismic modeling with applications to acquisition, processing, and interpretation, Geophysics, vol.72, issue.5, pp.1-4, 2007. ,
Seismic response of threedimensional alluvial valleys for incident P, S, and Rayleigh waves, Bull. seism. Soc. Am, vol.85, issue.1, pp.269-284, 1995. ,
Dispersion analysis of spectral elements methods for elastic wave propagation, Wave Motion, vol.45, pp.729-744, 2008. ,
Spectral element method for acoustic wave simulation in heterogeneous media, Finite Elements Anal. Des, vol.16, issue.34, pp.337-348, 1994. ,
Wave propagation modeling in highly heterogeneous media by a poly-grid Chebyshev spectral element method, J. Comp. Acous, vol.20, issue.02, p.1240004, 2012. ,
A new triangular and tetrahedral basis for high-order finite element methods, Int. J. Numer. Meth. Eng, vol.38, issue.2, pp.3775-3802, 1995. ,
Near-fault earthquake groundmotion simulation in the Grenoble Valley by a high-performance spectral element code, Bull. seism. Soc. Am, vol.99, issue.1, pp.286-301, 2009. ,
Earthquake groundmotion simulation including nonlinear soil effects under idealized conditions with application to two case studies, Seism. Res. Lett, vol.83, issue.6, pp.1047-1060, 2012. ,
A 3D hp-adaptive discontinuous Galerkin method for modeling earthquake dynamics, J. geophys. Res.: Solid Earth, vol.117, issue.B9, 2012. ,
An algorithm for computing Fekete points in a triangle, SIAM J. Numer. Anal, vol.38, issue.5, pp.1707-1720, 2000. ,
Spectral-element and adjoint methods in seismology, Commun. Comput. Phys, vol.3, pp.1-32, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00721213
P-SV wave propagation in heterogeneous media, velocitystress finite difference method, Geophysics, vol.51, pp.889-901, 1986. ,
Modelling Seismic Wave Propagation for Geophysical Imaging, Seismic Waves-Research and Analysis, vol.13, pp.253-304, 2012. ,
DOI : 10.5772/30219
URL : https://cdn.intechopen.com/pdfs/26255.pdf
An explicit construction of interpolation nodes on the simplex, J. Eng. Math, vol.56, pp.247-262, 2006. ,
DOI : 10.1007/s10665-006-9086-6
A pseudo-spectral scheme for the incompressible Navier-Stokes equations using unstructured nodal elements, J. Comput. Phys, vol.164, pp.1-21, 2000. ,
DOI : 10.1006/jcph.2000.6587
URL : https://infoscience.epfl.ch/record/190485/files/JCP2000.pdf
Regional wave propagation using the discontinuous Galerkin method, Solid Earth, vol.4, issue.1, pp.43-57, 2013. ,
, Advances in Wave Propagation in Heterogenous Earth, 2007.
Three-dimensional nonlinear seismic ground motion modeling in inelastic basins, Phys. Earth planet. Inter, vol.137, issue.1-4, pp.81-95, 2003. ,
DOI : 10.1016/s0031-9201(03)00009-8
High-order leap-frog methodology for the temporally dependent Maxwell's equations, Radio Sci, vol.36, pp.9-17, 2001. ,
DOI : 10.1029/2000rs002503
URL : http://onlinelibrary.wiley.com/doi/10.1029/2000RS002503/pdf
