Infinitesimal deformations of Levi flat hypersurfaces
In order to study the deformations of foliations of codimension 1 of a smooth manifold L, de Bartolomeis and Iordan defined the DGLA Z∗(L), where Z∗(L) is a subset of differential forms on L. In another paper, de Bartolomeis and Iordan studied the deformations of foliations of a smooth manifold L by defining the canonical solutions of Maurer–Cartan equation in the DGLA of graded derivations D∗(L). Let L be a Levi flat hypersurface in a complex manifold. Then the deformation theories in Z∗(L) and D∗(L) lead to the moduli space for the Levi flat deformations of L. In this paper we discuss the relationship between the infinitesimal deformations of L defined by the solutions of Maurer–Cartan equation in Z∗(L) and the infinitesimal deformations of L obtained by means of the canonical solutions of Maurer–Cartan equation in the DGLA of graded derivations D∗(L).
Iordan-2018-Bollettino_dell'Unione_Matematica_Italiana_sans marque.pdf (252.92 Ko)
Télécharger le fichier
