New interface
SLALOM - Open-Source Solar Cell Multivariate Optimizer
Abstract : SLALOM (SoLAr CelL Multivariate OptiMizer) is a set of open-source Python programs implementing a rigorous mathematical methods for the optimization of solar cells using as backend a drift-diffusion device simulator. It aims to be simple to use, to maintain and to extend. It includes a core optimizer using the well tested robust mathematical methods, A set of user interface utilities and some complete and working examples easily adaptable to new solar cell technologies. SLALOM uses, as device simulator, the Silvaco(C) Atlas tool. It can be easily extended to use any simulator that have a standard input format and a command line interface.
Complete list of metadata
Browse
Present sur SoftwareHeritage
swh:1:dir:35c5f1a11f22bdab179e37e69bdca43b4640d6a1;origin=https://hal.archives-ouvertes.fr/hal-01897934;visit=swh:1:snp:441755d289c857cc32ea7dcbf1280139e3856379;anchor=swh:1:rev:f370e484d8579b4ccc863d1c2a2f10decad21914;path=/
https://hal.inria.fr/hal-01897934
Contributor : Sidi OULD SAAD HAMADY Connect in order to contact the contributor
Submitted on : Tuesday, June 11, 2019 - 9:38:12 PM
Last modification on : Sunday, June 5, 2022 - 7:06:06 PM
Relations
Share
Metrics
Record views
432
Files downloads
89
