A New Optimal Control Approach for the Reconstruction of Extended Inclusions, SIAM Journal on Control and Optimization, vol.51, issue.2, pp.1372-1394, 2013. ,
A nudging-based data assimilation method: the Back and Forth Nudging (BFN) algorithm. Nonlinear Processes In Geophysics, vol.15, pp.305-319, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00331117
Displacement Reconstructions in Ultrasound Elastography, SIAM Journal on Imaging Sciences, vol.8, issue.2, pp.1070-1089, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01188761
Exponentially stable approximations of weakly damped wave equations, Estimation and control of distributed parameter systems, p.30, 1990. ,
Un exemple d'utilisation des notions de propagation pour le contrôle et la stabilisation des problèmes hyperboliques. Rendiconti del Seminario Matematico del Universita Politecnico Torino, Fascicolo speciale, pp.12-31, 1928. ,
Filtrage optimal des systèmes linéaires. Dunod, vol.2, p.12, 1971. ,
, Representation and Control of Infinite Dimensional Systems, vol.1, p.26, 1992.
Supersonic shear imaging: a new technique for soft tissue elasticity mapping, IEEE Trans Ultrason Ferr And Freq Control, vol.51, issue.4, pp.396-409, 2002. ,
A perfectly matched layer for the absorption of electromagnetic waves, J Comput Phys, vol.114, issue.2, p.30, 1994. ,
Exponential decay for the damped wave equation in unbounded domains, Commun. Contemp. Math, vol.18, issue.6, p.13, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01058120
Stabilisation of wave equations on the torus with rough dampings. working paper or preprint, vol.12, p.13, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01672371
Exponential Convergence of an Observer Based on Partial Field Measurements for the Wave Equation, Mathematical Problems in Engineering, vol.2012, issue.6, pp.1-12, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00619504
Exponential convergence of an observer based on partial field measurements for the wave equation, Mathematical Problems in Engineering, p.43, 2012. ,
Improving convergence in numerical analysis using observers The wave-like equation case, Mathematical Models and Methods in Applied Sciences (M3AS), vol.30, p.33, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00621052
A mixed formulation for the direct approximation of the control of minimal L 2 -norm for linear type wave equations, Calcolo, vol.52, issue.3, p.30, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00853767
A new approach to solve the inverse scattering problem for waves: combining the TRAC and the adaptive inversion methods, Inverse Problems, vol.29, issue.8, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00799110
Elastography: general principles and clincial applications, Ultrasound Clin, vol.9, issue.1, pp.1-11, 2002. ,
La palpationéchographique rythmée : Echosismographie. une nouvelle technique de différenciation des tumeurs bénignes et malignes par l'étude ultrasonore de l'élasticité tissulaire, J. Radiol, vol.64, issue.4, pp.255-261, 1983. ,
Regularization of inverse problems, Mathematics and its Applications, vol.375, p.12, 1996. ,
Absorbing boundary conditions for the numerical simulation of waves, Mathematics of Computations, vol.31, p.37, 1998. ,
Numerical meshes ensuring uniform observability of one-dimensional waves: construction and analysis, IMA Journal of Numerical Analysis, vol.36, issue.2 ,
URL : https://hal.archives-ouvertes.fr/hal-01859624
Uniform exponential decay for viscous damped systems, Progress in Nonlinear Differential Equations and their Applications, vol.78, p.30, 2009. ,
Uniformly exponentially stable approximations for a class of damped systems, Journal de Mathématiques Pures et Appliquées, vol.91, issue.1, p.30, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00681693
Perfectly matched layers in 1-d: energy decay for continuous and semi-discrete waves, Numer Math, vol.109, issue.4, p.30, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00681710
A mixed finite element formulation for the boundary controllability of the wave equation, International Journal for Numerical Methods in Engineering, vol.27, issue.3, p.30, 1989. ,
Exact nonreflecting boundary conditions for the time dependent wave equation, SIAM Journal on Applied Mathematics, vol.55, issue.2, pp.280-297, 1995. ,
On the Stability Analysis of Boundary Conditions for the Wave Equation by Energy Methods. Part I: The Homogeneous Case, Mathematics of Computation, vol.62, issue.206, p.24, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00075253
New Results on Absorbing Layers and Radiation Boundary Conditions, vol.38, pp.1-42, 2003. ,
A formulation of asymptotic and exact boundary conditions using local operators, Applied Numerical Mathematics, vol.27, issue.4, pp.403-416, 1998. ,
An observer-based approach for thermoacoustic tomography, The 21st International Symposium on Mathematical Theory of Networks and Systems, vol.8, p.48, 2006. ,
Recovering the observable part of the initial data of an infinite-dimensional linear system with skew-adjoint generator, Mathematics of Control Signals and Systems, vol.26, issue.3, pp.435-462, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00934239
Reconstructing initial data using observers: error analysis of the semi-discrete and fully discrete approximations, Numer Math, vol.120, issue.2, p.30, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00512824
Exact controllability of the wave equation with neumann boundary control, Applied Mathematics and Optimization, vol.19, issue.1, pp.243-290, 1924. ,
, Control Theory for Partial Differential Equations: Continuous and Approximation Theories, vol.1, p.24, 2000.
L 2 (?)-regularity of the boundary to boundary operator B * L for hyperbolic and Petrowski PDEs, Abstract Applied Analysis, vol.18, issue.19, p.25, 2003. ,
Geometric control condition for the wave equation with a timedependent observation domain, Anal. PDE, vol.10, issue.4, p.28, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01342398
Sharp Sufficient Conditions for the Observation, Control, and Stabilization of Waves from the Boundary, SIAM Journal on Control and Optimization, vol.30, issue.5, p.28, 1992. ,
Contrôle optimal de systèmes gouvernés par deséquations aux dérivées partielles. Avant propos de P. Lelong, 1968. ,
Propagation of 1D Waves in Regular Discrete Heterogeneous Media: A Wigner Measure Approach, Found Comput Math, vol.15, issue.6, p.33, 2015. ,
Shear wave speed recovery in transient elastography and supersonic imaging using propagating fronts, Inverse Problems, vol.22, issue.2, pp.681-706, 2002. ,
Strongly Elliptic systems and Boundary Integral equation, p.45, 2000. ,
Resolvent conditions for the control of unitary groups and their approximations, J. Spectr. Theory, vol.2, issue.1, p.30, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00620772
Joint state and parameter estimation for distributed mechanical systems, Comput Method Appl M, vol.197, issue.6-8, pp.659-677, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00175623
Finite Element Methods for Maxwell's Equations. Oxford science publications, p.45, 2003. ,
Stabilization of second order evolution equations with unbounded feedback with delay, ESAIM Control Optim. Calc. Var, vol.16, issue.2, p.23, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00599627
Semigroups of Linear Operators and Applications to Partial Differential Equations, Applied Mathematical Sciences, vol.44, p.18, 1983. ,
Vibration Control of Active Structures, An Introduction, p.33, 2002. ,
3D ultrafast ultrasound imaging in vivo, Phys Med Biol, vol.59, issue.19, pp.1-13, 2002. ,
Recovering the initial state of an infinite-dimensional system using observers, Automatica, vol.46, issue.10, p.15, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00529834
Thermoacoustic tomography with variable sound speed, Inverse Problems, vol.25, issue.7, pp.75011-75028, 2009. ,
Ultrafast imaging in biomedical ultrasound, 2014. ,
Observation and control for operator semigroups, vol.27, p.45, 1924. ,
URL : https://hal.archives-ouvertes.fr/hal-00590673
Propagation, Observation, and Control of Waves Approximated by Finite Difference Methods, SIAM Review, vol.47, issue.2, p.30, 2005. ,
