End-to-end timing analysis of cause-effect chains in automotive embedded systems, Journal of Systems Architecture-Embedded Systems Design, vol.80, pp.104-113, 2017. ,
A compositional frameworfor end-to-end path delay calculation of automotive systems under different path semantics, 2008. ,
A survey of schedulability analysis techniques for rate-dependent tasks, Journal of Systems and Software, vol.138, pp.100-107, 2018. ,
Estimating latencies of task sequences in multi-core automotive ecus, 2018. ,
Support for end-to-end response-time and delay analysis in the industrial tool suite: Issues, experiences and a case study, Comput. Sci. Inf. Syst, vol.10, issue.1, pp.453-482, 2013. ,
Functionally and temporally correct simulation of cyber-systems for automotive systems, 2017 IEEE Real-Time Systems Symposium, pp.68-79, 2017. ,
