A review of transparent and artificial boundary conditions techniques for linear and nonlinear Schrödinger equations, Commun. Comput. Phys, vol.4, issue.4, pp.729-796, 2008. ,
Stability of finite difference schemes for hyperbolic initial boundary value problems: Numerical boundary layers, Numer. Math. Theory Methods Appl, vol.10, issue.3, pp.489-519, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01114666
¨ Uber die partiellen Differenzengleichungen der mathematischen Physik, Math. Ann, vol.100, issue.1, pp.32-74, 1928. ,
Semigroup stability of finite difference schemes for multidimensional hyperbolic initial boundary value problems, Math. Comp, vol.80, issue.273, pp.165-203, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00383891
Numerical boundary layers for hyperbolic systems in 1-D, M2AN Math. Model. Numer. Anal, vol.35, issue.1, pp.91-106, 2001. ,
Stability of finite difference schemes for hyperbolic initial boundary value problems, HCDTE Lecture Notes. Part I. Nonlinear Hyperbolic PDEs, Dispersive and Transport Equations, pp.97-225, 2013. ,
Transparent numerical boundary conditions for evolution equations: derivation and stability analysis, Ann. Fac. Sci. Toulouse Math, issue.6, p.26, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01369975
Analyse mathématique et calcul numérique pour les sciences et les techniques ,
, , 1985.
Absorbing boundary conditions for the numerical simulation of waves, Math. Comp, vol.31, issue.139, pp.629-651, 1977. ,
Time dependent problems and difference methods, 1995. ,
Stability theory of difference approximations for mixed initial boundary value problems, II. Math. Comp, vol.26, issue.119, pp.649-686, 1972. ,
On a boundary extrapolation theorem by Kreiss, Math. Comp, vol.31, issue.138, pp.469-477, 1977. ,
Scheme-independent stability criteria for difference approximations of hyperbolic initial-boundary value problems, I. Math. Comp, vol.32, issue.144, pp.1097-1107, 1978. ,
Scheme-independent stability criteria for difference approximations of hyperbolic initial-boundary value problems, II. Math. Comp, vol.36, issue.154, pp.603-626, 1981. ,
The convergence rate for difference approximations to mixed initial boundary value problems, Math. Comp, vol.29, issue.130, pp.396-406, 1975. ,
Radiation boundary conditions for the numerical simulation of waves, Acta numerica, vol.8, pp.47-106, 1999. ,
Absorbing boundary conditions for the discretization schemes of the onedimensional wave equation, Math. Comp, vol.38, issue.158, pp.415-429, 1982. ,
Norms of powers of absolutely convergent Fourier series, Michigan Math. J, vol.13, pp.393-416, 1966. ,
Absorbing boundary conditions for difference approximations to the multidimensional wave equation, Math. Comp, vol.47, issue.176, pp.437-459, 1986. ,
Radiation boundary conditions for dispersive waves, SIAM J. Numer. Anal, vol.31, issue.1, pp.64-100, 1994. ,
On difference approximations with wrong boundary values, Math. Comp, vol.22, pp.1-12, 1968. ,
Difference approximations for hyperbolic differential equations, Numerical Solution of Partial Differential Equations (Proc. Sympos. Univ. Maryland, 1965), pp.51-58, 1966. ,
Stability theory for difference approximations of mixed initial boundary value problems, I. Math. Comp, vol.22, pp.703-714, 1968. ,
Systems of difference equations with general homogeneous boundary conditions, Trans. Amer. Math. Soc, vol.137, pp.177-201, 1969. ,
Trigonometric polynomials and difference methods of maximum accuracy, J. Math. Phys, vol.41, pp.147-154, 1962. ,
Finite difference schemes and partial differential equations, Society for Industrial and Applied Mathematics, issue.SIAM, 2004. ,
, The behavior of nonnormal matrices and operators, 2005.
Stability of difference schemes in the maximum-norm, J. Differential Equations, vol.1, pp.273-292, 1965. ,
Instability of difference models for hyperbolic initial-boundary value problems, Comm. Pure Appl. Math, vol.37, issue.3, pp.329-367, 1984. ,
The semigroup stability of the difference approximations for initial-boundary value problems, Math. Comp, vol.64, issue.209, pp.71-88, 1995. ,
