Comparison of batch 627 sorption tests , pilot studies , and modeling for estimating GAC bed life, Water Res, vol.44, pp.769-780, 2010. ,
Three-component 630 competitive adsorption model for fixed-bed and moving-bed granular activated carbon 631 adsorbers. Part I. Model development, Environ. Sci. Technol, vol.40, pp.6805-6811, 2006. ,
Three-component 634 competitive adsorption model for fixed-bed and moving-bed granular activated carbon 635 adsorbers. Part II. Model parameterization and verification, Environ. Sci. Technol, vol.40, pp.6812-6817, 2006. ,
Modeling the adsorption of target compounds 638 by GAC in the presence of background dissolved organic matter, Environ. Prog, vol.6, pp.18-639, 1987. ,
Effect of preloading on the scale-up of GAC microcolumns, 1989. ,
, Am. Water Work. Assoc, vol.81, pp.141-148
Solution of Boundary Value Problems by Orthogonal 643 collocation, Chem. Eng. Sci, vol.22, issue.96, pp.81831-81839, 1967. ,
Screening of pharmaceuticals and hormones at the regional 646 scale, in surface and groundwaters intended to human consumption, Environ. Chem. Lett, vol.159, pp.650-103, 2011. ,
Effect of fluid dispersion coefficients on particle-to-fluid mass 652 transfer coefficients in packed beds, Chem. Eng. Sci, vol.33, pp.1375-1384, 1978. ,
, , pp.85120-85123
Liquid mass transfer at very low reynolds numbers in 655 packed beds, Ind. Eng. Chem. Fundam, vol.5, pp.9-14, 1966. ,
Adsorption of selected pharmaceuticals and an 657 endocrine disrupting compound by granular activated carbon. 1. Adsorption capacity and 658 kinetics, Environ. Sci. Technol, vol.43, pp.1467-1473, 2009. ,
User-oriented batch 660 reactor solutions to the homogeneous surface diffusion model for different activated 661 carbon dosages, Water Res, vol.43, pp.1859-1866, 2009. ,
Impact of EfOM size on competition in activated carbon adsorption of organic 664 micro-pollutants from treated wastewater, Water Res, vol.663, pp.297-306, 2014. ,
