Motion planning and obstacle avoidance, Springer Handbook of Robotics, pp.827-852, 2008. ,
Algorithms for collisionfree navigation of mobile robots in complex cluttered environments: a survey, Robotica, vol.33, issue.3, pp.463-497, 2015. ,
Heuristic approaches in robot path planning: A survey, Robotics and Autonomous Systems, vol.86, pp.13-28, 2016. ,
On multiple moving objects, Algorithmica, vol.2, pp.477-521, 1987. ,
Motion planning in a dynamic domain, ICRA 1990, vol.1, pp.324-330, 1990. ,
New lower bound techniques for robot motion planning problems, 28th IEEE Syrup. on Foundations of Computer Science, pp.49-60, 1987. ,
Planning time-minimal safe paths amidst unpredictably moving obstacles, I. J. Robotics Res, vol.27, issue.11-12, pp.1274-1294, 2008. ,
A time-dependent hamilton-jacobi formulation of reachable sets for continuous dynamic games, IEEE Transactions on Automatic Control, vol.50, issue.7, pp.947-957, 2005. ,
The dynamic window approach to collision avoidance, IEEE Robot. Automat. Mag, vol.4, issue.1, pp.23-33, 1997. ,
Obstacle avoidance in a dynamic environment: a collision cone approach, Man, and Cy rnetics, vol.28, pp.562-574, 1998. ,
Motion planning in dynamic environments using velocity obstacles, I. J. Robotics Res, vol.17, issue.7, pp.760-772, 1998. ,
Reciprocal velocity obstacles for real-time multi-agent navigation, pp.1928-1935, 2008. ,
Generalized velocity obstacles, IROS 2009, pp.5573-5578, 2009. ,
, Robot Motion Planning. Kluwer, 1991.
Avoidability measure in moving obstacle avoidance problem and its use for robot motion planning, IROS 1996, vol.3, pp.1296-1303, 1996. ,
Dynamic motion planning for mobile robots using potential field method, Autonomous Robots, vol.13, issue.3, pp.207-222, 2002. ,
Velocity planning for a mobile robot to track a moving target-a potential field approach, Robotics and Autonomous Systems, vol.57, issue.1, pp.55-63, 2009. ,
Autonomous vehicle navigation utilizing electrostatic potential fields and fuzzy logic, IEEE Trans. Robotics and Automation, vol.17, issue.4, pp.490-497, 2001. ,
Pathguided artificial potential fields with stochastic reachable sets for motion planning in highly dynamic environments, ICRA 2015, pp.2347-2354, 2015. ,
Hybrid dynamic moving obstacle avoidance using a stochastic reachable setbased potential field, IEEE Trans. Robotics, issue.99, pp.1-15, 2017. ,
Planning Algorithms, 2006. ,
Reachable set approach to collision avoidance for uavs, 54th IEEE Conference on Decision and Control (CDC), pp.5947-5952, 2015. ,
Sampling-based algorithms for optimal motion planning, I. J. Robotics Res, vol.30, issue.7, pp.846-894, 2011. ,
Geometric Modeling, 1997. ,
RVO2 library: Reciprocal collision avoidance for real-time multiagent simulation, 2009. ,
