Long time behavior of a mean-field model of interacting neurons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2020
We study the long time behavior of the solution to some McKean-Vlasov stochastic differential equation (SDE) driven by a Poisson process. In neuroscience, this SDE models the asymptotic dynamic of the membrane potential of a spiking neuron in a large network. We prove that for a small enough interaction parameter, any solution converges to the unique (in this case) invariant measure. To this aim, we first obtain global bounds on the jump rate and derive a Volterra type integral equation satisfied by this rate. We then replace temporary the interaction part of the equation by a deterministic external quantity (we call it the external current). For constant current, we obtain the convergence to the invariant measure. Using a perturbation method, we extend this result to more general external currents. Finally, we prove the result for the non-linear McKean-Vlasov equation.
CTV.pdf (513.71 Ko) Télécharger le fichier
hal-01903857 , version 1 (24-10-2018)
hal-01903857 , version 2 (14-05-2019)
hal-01903857 , version 3 (14-08-2020)
Quentin Cormier, Etienne Tanré, Romain Veltz. Long time behavior of a mean-field model of interacting neurons. Stochastic Processes and their Applications, 2020, 130 (5), pp.2553-2593. ⟨10.1016/j.spa.2019.07.010⟩. ⟨hal-01903857v3⟩
440 Consultations
308 Téléchargements
