Cycle Height of Finite Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Chris Keeler
  • Fonction : Auteur
  • PersonId : 1024582
Kai Salomaa
  • Fonction : Auteur
  • PersonId : 1022715
A nondeterministic finite automaton (NFA) A has cycle height $$\mathcal {K}$$ if any computation of A can visit at most $$\mathcal {K}$$ cycles, and A has finite cycle height if it has cycle height $$\mathcal {K}$$ for some $$\mathcal {K}$$. We give a polynomial time algorithm to decide whether an NFA has finite cycle height and, in the positive case, to compute its optimal cycle height. Nondeterministic finite automata of finite cycle height recognize the polynomial density regular languages.
470153_1_En_17_Chapter.pdf (313.84 Ko) Télécharger le fichier
hal-01905622 , version 1 (26-10-2018)
Paternité
Chris Keeler, Kai Salomaa. Cycle Height of Finite Automata. 20th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2018, Halifax, NS, Canada. pp.200-211, ⟨10.1007/978-3-319-94631-3_17⟩. ⟨hal-01905622⟩
53 Consultations
127 Téléchargements
