A New Technique for Reachability of States in Concatenation Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Sylvie Davies
  • Fonction : Auteur
  • PersonId : 1024581
We present a new technique for demonstrating the reachability of states in deterministic finite automata representing the concatenation of two languages. Such demonstrations are a necessary step in establishing the state complexity of the concatenation of two languages, and thus in establishing the state complexity of concatenation as an operation. Typically, ad-hoc induction arguments are used to show particular states are reachable in concatenation automata. We prove some results that seem to capture the essence of many of these induction arguments. Using these results, reachability proofs in concatenation automata can often be done more simply and without using induction directly.
470153_1_En_7_Chapter.pdf (152.35 Ko) Télécharger le fichier
hal-01905633 , version 1 (26-10-2018)
Paternité
Sylvie Davies. A New Technique for Reachability of States in Concatenation Automata. 20th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2018, Halifax, NS, Canada. pp.75-87, ⟨10.1007/978-3-319-94631-3_7⟩. ⟨hal-01905633⟩
236 Consultations
43 Téléchargements
