A Local Limit Property for Pattern Statistics in Bicomponent Stochastic Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We present a non-Gaussian local limit theorem for the number of occurrences of a given symbol in a word of length n generated at random. The stochastic model for the random generation is defined by a rational formal series with non-negative real coefficients. The result yields a local limit towards a uniform density function and holds under the assumption that the formal series defining the model is recognized by a weighted finite state automaton with two primitive components having equal dominant eigenvalue.
470153_1_En_10_Chapter.pdf (173.6 Ko) Télécharger le fichier
hal-01905636 , version 1 (26-10-2018)
Paternité
Massimiliano Goldwurm, Jianyi Lin, Marco Vignati. A Local Limit Property for Pattern Statistics in Bicomponent Stochastic Models. 20th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2018, Halifax, NS, Canada. pp.114-125, ⟨10.1007/978-3-319-94631-3_10⟩. ⟨hal-01905636⟩
44 Consultations
62 Téléchargements
