Formal Proofs of Tarjan's Algorithm in Why3, Coq, and Isabelle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Comparing provers on a formalization of the same problem is always a valuable exercise. In this paper, we present the formal proof of correctness of a non-trivial algorithm from graph theory that was carried out in three proof assistants: Why3, Coq, and Isabelle.
paper.pdf (409.99 Ko) Télécharger le fichier
hal-01906155 , version 1 (26-10-2018)
Ran Chen, Cyril Cohen, Jean-Jacques Levy, Stephan Merz, Laurent Thery. Formal Proofs of Tarjan's Algorithm in Why3, Coq, and Isabelle. 2018. ⟨hal-01906155⟩
242 Consultations
290 Téléchargements
