New interface
Conference papers
Youla-Kucera Based Lateral Controller for Autonomous Vehicle
Abstract : This paper presents the design and implementation of a novel lateral control approach. The proposed control strategy is based on Youla-Kucera parametrization to switch gradually between controllers that are designed separately for big and small lateral errors. The present approach studies the critical problem of initial lateral error in line following. It ensures smooth and stable transitions between controllers and provides a smooth vehicle response regardless of the lateral error. For an initial validation the present work was tested in simulation, implementing a dynamic bicycle model. It has also been tested in real platforms implementing an electric Renault ZOE, with good results when activating the system at different lateral errors. autonomous vehicles Switched controllers parametrization.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01906268
Contributor : imane mahtout Connect in order to contact the contributor
Submitted on : Friday, October 26, 2018 - 3:54:27 PM
Last modification on : Wednesday, June 8, 2022 - 12:50:05 PM
Long-term archiving on: : Sunday, January 27, 2019 - 2:53:19 PM
File
Youla-Kucera_2018.pdf
Identifiers
  • HAL Id : hal-01906268, version 1
Collections
Citation
Imane Mahtout, Francisco Navas, David Gonzalez, Vicente Milanés, Fawzi Nashashibi. Youla-Kucera Based Lateral Controller for Autonomous Vehicle. ​ITSC 2018 - 21st IEEE International Conference on Intelligent Transportation Systems, Nov 2018, Maui, Hawaii, U.S. Outlying Islands. ⟨hal-01906268⟩
Share
Metrics
Record views
211
Files downloads
570
