Optimistic optimization of a Brownian - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Jean-Bastien Grill
  • Fonction : Auteur
  • PersonId : 972490
Michal Valko
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
We address the problem of optimizing a Brownian motion. We consider a (random) realization W of a Brownian motion with input space in [0, 1]. Given W, our goal is to return an ε-approximation of its maximum using the smallest possible number of function evaluations, the sample complexity of the algorithm. We provide an algorithm with sample complexity of order log 2 (1/ε). This improves over previous results of Al-Mharmah and Calvin (1996) and Calvin et al. (2017) which provided only polynomial rates. Our algorithm is adaptive-each query depends on previous values-and is an instance of the optimism-in-the-face-of-uncertainty principle.
grill2018optimistic.pdf (1.21 Mo) Télécharger le fichier
hal-01906601 , version 1 (27-10-2018)
hal-01906601 , version 2 (13-01-2019)
  • HAL Id : hal-01906601 , version 2
Jean-Bastien Grill, Michal Valko, Rémi Munos. Optimistic optimization of a Brownian. NeurIPS 2018 - Thirty-second Conference on Neural Information Processing Systems, Dec 2018, Montréal, Canada. ⟨hal-01906601v2⟩
150 Consultations
129 Téléchargements
