New links between nonlinearity and differential uniformity
In this paper some new links between the nonlinearity and differential uniformity of some large classes of functions are established. Differentially two-valued functions and quadratic functions are mainly treated. A lower bound for the nonlinearity of monomial δ-uniform permutations is obtained, for any δ, as well as an upper bound for differentially two-valued functions. Concerning quadratic functions, significant relations between nonlinearity and differential uniformity are exhibited. In particular, we show that the quadratic differentially 4-uniform permutations should be differentially two-valued and possess the best known nonlinearity.
