A conservative penalisation strategy for the semi-implicit time discretisation of incompressible elastodynamics equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
The principal aim of this work is to provide an adapted numerical scheme for the approximation of elastic wave propagation in incompressible solids. We rely on high-order conforming finite element with mass lumping for space discretisation and implicit/explicit, second-order, energy-preserving time discretisation. The time step restriction only depends on the shear wave velocity and at each time step a Poisson problem must be solved to account for the incompressibility constraint that is imposed by penalisation techniques.
article_incompressibility.pdf (11.08 Mo) Télécharger le fichier
hal-01907746 , version 1 (29-10-2018)
hal-01907746 , version 2 (23-11-2018)
  • HAL Id : hal-01907746 , version 1
Federica Caforio, Sebastien Imperiale. A conservative penalisation strategy for the semi-implicit time discretisation of incompressible elastodynamics equation. 2018. ⟨hal-01907746v1⟩
376 Consultations
147 Téléchargements
