Stabilization of systems with switchings on the axis of their coordinates and its input-to-state properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2019
The stabilization problem for switched systems in which switchings occur on the axes of its state coordinates is considered. It is shown that a linear feedback, or a combination of linear feedback and a switching law, can be designed such that the closed-loop is stable, and has the input-to-state property, allowing to guarantee robustness against matched and unmatched perturbations. The conditions of stability are expressed in the form of linear matrix inequalities. The results are illustrated by numerical simulations.
Swithed_stabilization_rev2_final.pdf (1.06 Mo) Télécharger le fichier
hal-01908289 , version 1 (30-10-2018)
Andrea Aparicio, Leonid Fridman, Denis Efimov. Stabilization of systems with switchings on the axis of their coordinates and its input-to-state properties. Nonlinear Analysis: Hybrid Systems, inPress, ⟨10.1016/j.nahs.2018.10.008⟩. ⟨hal-01908289⟩
84 Consultations
188 Téléchargements
