Approximation and model management in aerodynamic optimization with variable-fidelity models, Journal of Aircraft, vol.38, issue.6, pp.1093-1101, 2001. ,
Modifications and clarifications for the implementation of the spalart-allmaras turbulence model, Seventh international conference on computational fluid dynamics (ICCFD7), pp.1-11, 2012. ,
Turbomachinery design by a swarm-based optimization method coupled with a cfd solver, Advances in aircraft and spacecraft science, vol.3, issue.2, pp.149-170, 2016. ,
Interpolation method for adapting reduced-order models and application to aeroelasticity, AIAA journal, vol.46, issue.7, pp.1803-1813, 2008. ,
Nonlinear model order reduction based on local reduced-order bases, International Journal for Numerical Methods in Engineering, vol.92, issue.10, pp.891-916, 2012. ,
Design optimization using hyper-reduced-order models. Structural and Multidisciplinary Optimization, vol.51, pp.919-940, 2015. ,
Local proper generalized decomposition, AIP Conference Proceedings, vol.1896, p.170007, 2017. ,
A domain decomposition strategy for reduced order models. application to the incompressible navier-stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.23-42, 2013. ,
An 'empirical interpolation' method: application to efficient reduced-basis discretization of partial differential equations, Comptes Rendus Mathematique, vol.339, issue.9, pp.667-672, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00021702
On the flexibility of agglomeration based physical space discontinuous galerkin discretizations, Journal of Computational Physics, vol.231, issue.1, pp.45-65, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00562219
Enablers for robust pod models, Journal of Computational Physics, vol.228, issue.2, pp.516-538, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00338203
Reduced order models at work in aeronautics and medicine, Reduced Order Methods for Modeling and Computational Reduction, pp.305-332, 2014. ,
A zonal galerkin-free pod model for incompressible flows, Journal of Computational Physics, vol.352, pp.301-325, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01668546
Towards an adaptive pod/svd surrogate model for aeronautic design, Computers & Fluids, vol.40, issue.1, pp.195-209, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01298892
Projection-based model reduction for reacting flows, 40th Fluid Dynamics Conference and Exhibit, p.5008, 2010. ,
Iterative methods for model reduction by domain decomposition, Computers & Fluids, vol.38, issue.6, pp.1160-1167, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00193962
A dynamic p-adaptive discontinuous galerkin method for viscous flow with shocks, Computers & fluids, vol.34, issue.4-5, pp.401-417, 2005. ,
A numerical investigation of velocity-pressure reduced order models for incompressible flows, Journal of Computational Physics, vol.259, pp.598-616, 2014. ,
A compact proper orthogonal decomposition basis for optimization-oriented reduced-order models, 12th AIAA/ISSMO Multidisciplinary Analysis and Optimization Conference, p.5964, 2008. ,
Efficient non-linear model reduction via a least-squares petrov-galerkin projection and compressive tensor approximations, International Journal for Numerical Methods in Engineering, vol.86, issue.2, pp.155-181, 2011. ,
Nonlinear model reduction via discrete empirical interpolation, SIAM Journal on Scientific Computing, vol.32, issue.5, pp.2737-2764, 2010. ,
Pgd-based computational vademecum for efficient design, optimization and control, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.31-59, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01515083
Aerodynamic data predictions for transonic flows via a machine-learning-based surrogate model, 2018 AIAA/ASCE/AHS/ASC Structures, Structural Dynamics, and Materials Conference, p.1905, 2018. ,
Feedback filtering in discontinuous galerkin methods for euler equations. Progress in Computational Fluid Dynamics, an International Journal, vol.16, issue.1, pp.14-25, 2016. ,
Adaptive cfd schemes for aerospace propulsion, Journal of Physics: Conference Series, vol.841, issue.1, 2017. ,
A robust and adaptive recovery-based discontinuous galerkin method for the numerical solution of convection-diffusion equations, International Journal for Numerical Methods in Fluids, vol.77, issue.2, pp.63-91, 2015. ,
Unstructured discretisation of a nonlocal transition model for turbomachinery flows. Advances in aircraft and spacecraft science, vol.4, pp.555-571, 2017. ,
Gmsh: A 3-d finite element mesh generator with built-in pre-and post-processing facilities, International journal for numerical methods in engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
Adaptive discontinuous galerkin finite element methods for the compressible euler equations, Journal of Computational Physics, vol.183, issue.2, pp.508-532, 2002. ,
Assessment of a high-order discontinuous galerkin method for the direct numerical simulation of transition at low-reynolds number in the t106c high-lift low pressure turbine cascade, ASME Turbo Expo 2014: Turbine Technical Conference and Exposition, pp.2-39, 2014. ,
Modeling of transitional channel flow using balanced proper orthogonal decomposition, Physics of Fluids, vol.20, issue.3, p.34103, 2008. ,
Efficient global optimization of expensive black-box functions, Journal of Global optimization, vol.13, issue.4, pp.455-492, 1998. ,
A new local reduced basis discontinuous galerkin approach for heterogeneous multiscale problems, Comptes Rendus Mathematique, vol.349, pp.1233-1238, 2011. ,
, , 2014.
The reduced basis element method: application to a thermal fin problem, SIAM Journal on Scientific Computing, vol.26, issue.1, pp.240-258, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00021699
The need for a pressure-term representation in empirical galerkin models of incompressible shear flows, Journal of Fluid Mechanics, vol.523, pp.339-365, 2005. ,
Upwind difference schemes for hyperbolic systems of conservation laws, Mathematics of computation, vol.38, issue.158, pp.339-374, 1982. ,
A contribution to the numerical prediction of unsteady flows, AIAA journal, vol.22, issue.5, pp.602-610, 1984. ,
Survey of multifidelity methods in uncertainty propagation, inference and optimization, 2016. ,
Reduced order methods for modeling and computational reduction, vol.9, 2014. ,
Certified reduced basis approximation for parametrized partial differential equations and applications, Journal of Mathematics in Industry, vol.1, issue.1, p.3, 2011. ,
Model reduction for fluids, using balanced proper orthogonal decomposition, International Journal of Bifurcation and Chaos, vol.15, issue.03, pp.997-1013, 2005. ,
Model reduction for compressible flows using pod and galerkin projection, Physica D: Nonlinear Phenomena, vol.189, issue.1, pp.115-129, 2004. ,
A priori hyperreduction method: an adaptive approach, Journal of computational physics, vol.202, issue.1, pp.346-366, 2005. ,
DOI : 10.1016/j.jcp.2004.07.015
Dynamic mode decomposition of numerical and experimental data, Journal of fluid mechanics, vol.656, pp.5-28, 2010. ,
Equationfree/galerkin-free pod-assisted computation of incompressible flows, Journal of Computational Physics, vol.207, issue.2, pp.568-587, 2005. ,
Turbulence and the dynamics of coherent structures part i: coherent structures, Quarterly of applied mathematics, vol.45, issue.3, pp.561-571, 1987. ,
Summary of the delft university wind turbine dedicated airfoils, Journal of solar energy engineering, vol.125, issue.4, pp.488-496, 2003. ,
DOI : 10.2514/6.2003-352
Adaptive sampling strategies for nonintrusive pod-based surrogates. Engineering computations, vol.30, pp.521-547, 2013. ,
Adjoint-based h-p adaptive discontinuous galerkin methods for the 2d compressible euler equations, Journal of Computational Physics, vol.228, issue.20, pp.7643-7661, 2009. ,
Two-level discretizations of nonlinear closure models for proper orthogonal decomposition, Journal of Computational Physics, vol.230, issue.1, pp.126-146, 2011. ,
An evolve-then-filter regularized reduced order model for convection-dominated flows, International Journal for Numerical Methods in Fluids, vol.84, issue.10, pp.598-615, 2017. ,
DOI : 10.1002/fld.4363
Balanced model reduction via the proper orthogonal decomposition, AIAA journal, vol.40, issue.11, pp.2323-2330, 2002. ,
DOI : 10.2514/6.2001-2611
A multilevel projection-based model order reduction framework for nonlinear dynamic multiscale problems in structural and solid mechanics, International Journal for Numerical Methods in Engineering, vol.112, issue.8, pp.855-881, 2017. ,
Local reduced-order modeling and iterative sampling for parametric analyses of aero-icing problems, AIAA Journal, vol.53, issue.8, pp.2174-2185, 2015. ,
