Journal articles
Differential uniformity and the associated codes of cryptographic functions
Abstract : The associated codes of almost perfect nonlinear (APN) functions have been widely studied. In this paper we consider more generally the codes associated with functions that have differential uniformity at least 4. We emphasize, for such a function F , the role of codewords of weight 3 and 4 and of some cosets of its associated code C F. We give some properties on codes associated with differential uniformity exactly 4. We obtain lower bounds and upper bounds for the numbers of codewords of weight less than 5 of the codes C F. We show that the nonlinearity of F decreases when these numbers increase. We obtain a precise expression to compute these numbers when F is a plateaued or a differentially two-valued function. As an application, we propose a method to construct differentially 4-uniform functions with a large number of 2-to-1 derivatives from APN functions.
Document type :
Journal articles
Complete list of metadatas
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-01908336
Contributor : Pascale Charpin <>
Submitted on : Friday, February 8, 2019 - 12:56:59 PM
Last modification on : Tuesday, December 31, 2019 - 4:44:15 PM
Document(s) archivé(s) le : Thursday, May 9, 2019 - 1:41:13 PM
File
Charpinpeng-2019.pdf
Identifiers
Collections
Citation
Pascale Charpin, Jie Peng. Differential uniformity and the associated codes of cryptographic functions. Advances in Mathematics of Communications, AIMS, 2019, 13 (4), pp.579-600. ⟨10.3934/amc.2019036⟩. ⟨hal-01908336v3⟩
Share
Metrics
Record views
206
Files downloads
365
